Date: 09/09/2018 03:22 pm
Date: 09/15/2019 08:30 pm
Date: 10/14/2019 08:24 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 10/24/2019 01:45 pm
Date: 04/13/2017 04:56 am
cam pulley
Date: 05/30/2018 04:56 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
  • Online today: 583
  • Guests: 508
  • Total: 508
OIL FILTER LOOSENING
Started by COOKIE, April 28, 2010, 01:15:03 AM
The starter continuing to run is the solenoid on the fender or firewall. 15 bucks & 15 minutes work. Ditto what Fred said about the old gasket. Make sure there is only the new gasket & spin it on till it contacts the mounting point then turn it by hand about 3/4 turn. Dont use a wrench to tighten it, just your hand.
On starter check to see if selenoid on wheel well is sticking closed. Oil filter see if there is old rubber gasket from last filter stuck on engine.  Fred   :)
COOKIE
Bought a 1979 Pinto wagon put rebuilt 2.3 motor in it two problems after car starts starter motor will keep running not always.2nd problem oil filter keeps loosening.Have tried different filters teflon tape on threads wrenching it down.Still loosens and drops all oil.I have put almost 2000 in  the car. I need help
