Date: 02/21/2017 06:29 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 01/28/2021 03:49 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 03/25/2019 09:02 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Total Topics: 16,268
  • Online today: 318
  • Guests: 255
  • Total: 255
The Pinto of the desert passed CA smog..
Started by D.R.Ball, April 10, 2010, 10:32:21 PM
chrisf1219
having gone thur this lasy year the 15 and 25 load on the treadmill to test it underload. but you also have the fuel vapor pressure test to worry about to pass. my 77 failed then i found out it had a small hairline crck in the line that leaked. repair that and it passed with flying colors.hofefully they dont get anymore creavtive in the furture!  chis in central ca.
entropy
Quote from: 75bobcatv6 on April 11, 2010, 11:42:40 AM
Why would the state of CA dyno test a car now? lol cant make more then a certain hp to be legal?
No, they run the smog tests on a dyno.  Probably in order to test the car under load...
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Well after much to do about nothing the pinto passed smog. The first time it failed due to timing being set advanced to much . But everthing else was with in limits ie CO2 at idle 8.40 02 8.4 HC 84 CO .28 2500 CO2 9.02 O2 7.7 HC 56 CO2 .30  . So after adjusting the timing and idle the results were Idle CO2 8.40 O2 8.6 HC 205 CO .22 and at 2500 CO2 9.40 O2 7.2 HC 535 CO .17.  So I think the carb is not set right again but I have to see...And how did I get it to pass, well it took removing the carb and carb plate, removing the egr and cleaning the Hell out of the egr passages,(they where really gunked up),change the spark plugs and reset the engine timing. And that's it...BTW I live North Eastern Kern county so no dyno test...  :o
