Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 03/25/2019 09:02 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 10/24/2019 01:43 pm
Date: 10/05/2017 02:26 pm
Date: 03/23/2018 09:23 pm
Date: 03/13/2021 12:57 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 10/11/2019 11:13 am
  • Online today: 600
  • Guests: 328
  • Total: 328
Will a 8.8 mustang fit in my '72 coupe
Started by 1qkwagon, April 04, 2010, 10:31:11 AM
1qkwagon
Thanks for the info, I'm going to use the 8.8 as I've had really good luck with them holding up in my wagon, Its pretty easy to come by them  for cheap ($50-150) the mustang 65-73 not so much.
OhSix9
get a 9 inch from an early mustang 65-73. its narrow enough to fit and will take the pain. the 8.8 without a girdle isn't really any stronger than the 8 inch you already have. plus ratio changes require setting the unit up again. if it is a track only car spool it to boot or have 2 pumpkins. one spooled with track gearing and a 2nd locker/open for street use and fuel mileage.  only takes about 20 minutes to swap the carrier
OhSix'
Virgil to Sid
1qkwagon
Thanks, I will be well over the 350 h/p mark w/o spray.......
OhSix9
Yes the 8.8 will fit in the car. you will need to chop off all the old mounts and weld in new spring pads. also the wheel backspacing will be affected depending on how wide the new unit is. the advantages of the 8.8 are that there is a ton of aftermarket support out there with gear sets and lockers,  you can beef it up substantially with a bearing girdle and c clip eliminators
The 8 inch that you already have is essentially indestructible up to about 350 horses as it is a downsized version of the 9 inch and has the added advantage of having a quick change center carrier that is handy when racing.  Unless you are well over the 350 horse mark or making big v8 torque you may want to stick with the 8 inch.   it is also a clipless rear end so if an axle explodes it will not drop the wheel off the corner of the car.
good luck with your modding
OhSix'
Virgil to Sid
1qkwagon
I have an 8" rear in my '72 pinto but want something stronger (as it will be raced) SO, will a 8.8 work in this car? Thanks for any help......
