Date: 06/25/2021 12:59 am
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
80 pinto original
Date: 08/04/2019 10:45 am
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 01/12/2019 10:19 am
Date: 10/27/2018 03:30 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 02/10/2017 09:30 am
  • Online today: 600
  • Guests: 262
  • Total: 262
Things That Make You Go Hmmmm....
Started by blupinto, March 26, 2010, 06:29:44 PM
According to my Pinto repair manuals there's a cylindrical PCV valve where the hose is. This is definitelt making me go hmmmm.....
Ha! That's what I said! What th' heck is that?? ??? Hey Dwayne, can you take a peek at your 1600 and see if it has that tube? :lost:
that hose with the wire loom and zip tie i really doubt its supposed to be sittin in there like that lol not sure whe it goes though since i never messed with a 1600.
Now David, why in the everlovin' blue-eyed world would I want to install a V8... she's plenty powerful enough!
Here's some pix of the air cleaner interior. Yes I'm aware that the filters need to be cleaned/replaced. That tube thingy I'm holding up is suspicious. Also, does that tube that goes from the air cleaner to the cannister below have anything funny-looking (besides it being disconnected at the air cleaner)?
There are a couple things I've observed today. The first is the engine light stays on as long as I keep the car in neutral when I first start Ruby up. After warm-up I sometimes coast her to the stop sign and the light stays on. When I put her in first gear the light flickers, then goes out. When I park, say, at the store When I start her again the light only comes on when the key is turned- like it should- then it goes out.
She doesn't always smoke-at least badly- on acceleration. She will if there's a load (like an incline starting from a stop) on her but once we hit 3rd there's no visible smoke.
Ok Becky here is my official diagnosis, and first let me say im probably wrong. But i believe you have worn valve guides and the vavle seals are bad and this is letting oil burn which usually only shows up under acceleration and also allows crank case pressure to build a little which may be whats causing the oil to be blown up thru the pvc. But again i am almost always wrong.  :lol: :lol:
And i really hope Jim is write on the light hope its a bad sender. Other wise it might be time to have a V8.  ;)
If you have bad oil seals when you change oil the oil gets more time to soak around the valves and leak in to the cylinders, and will smoke worse on the first start up and acceleration but will get better and do it less after you drive it the first time.
I'll take a picture of the inside of the air cleaner and you can be the judge... ;D
still sounds like a pcv system problem to me. But then again im not to big of an expert on those 1600's now if it was a 2.3 id say at 116k its just in it break in stages LOL.
No, 10w40 should be fine. I'm thinking that since the engine is nice and quiet the oil pressure sender is at fault. As far as the smoking, hmmmmm.....
No, no strange noises (well, the engine running so quietly and starting right up IS weird...lol. I do know the oil that came out of her pan seemed to me (in hindsight) thicker than what I'd put in. So should I drain the oil and put something thicker in?
Hmmmmm, I'm not liking the sound of this Becky, smoking, engine light on for 5 mins, whats next, rods knocking?? (OOOH bad pintoracer, bad!!) Hope the PO didn't fill her full of STP or something so they could get rid of her!! And no, a dirty air filter will not cause this. Any unusual noises on cold start up or while the engine light is on? Hopefully it is just a faulty oil sender.
Id say your best bet would be take the filter to a parts store and see if they can cross reference it to some other kind of car if they dont have one listed for it.
I'm noticing that Ruby doesn't always smoke at acceleration... at least not too bad. Other times there's an oil cloud behind us.  :-\
Something else that makes me go hmmm... Every time I start Ruby- regardless whether her front end points up or down at an angle (as on a slanted driveway) - her ENGINE light comes on and stays on for about 5 minutes. I have checked her oil level (of course oil and filter was changed) and coolant. Could the culprit be the dirty air filter? Where can I find one for a 1600?
Yeah, I'll take a pic of the inside of the air cleaner (where the PCV is). There's a tube where the PCV should be... and the air filter's filthy, but O'Reilly's or Napa didn't have an air filter for a 1.6  but Napa will have one in a couple weeks.  The motor has about 116,300something on it. The engine hauls arse. ;D
Blueish white smoke usually is oil white smoke water and blackish gray smoke fuel.
That being said check the pcv valve as carolina boy stated cause if the original oil was thicker or extremly dirty it may have not been able to pass through the pvc valve but the new oil if thinner and cleaner can. Also how many miles is on the motor?
Jim, the dipstick now reads well between the Min and Max lines. I put 4 quarts in her.  As for the PCV valve... I'll have to send pix of thast. The setup looks nothing like the pictures in the book. Why wouldn't it billow smoke before the oil change, though?
Becky, make sure you didn't put too much oil in her, might also want to check the PCV valve. 10w40 is fine. :)
Ruby's appears to be more like oil, and fuel smoke is usually black... this is real weird...as she hadn't smoked til after I changed her oil.
I don't have an answer but that is what Bella does! She runs great at idle but as soon as I give her gas, she smokes! Hubby thinks it may be the carb dumping to much raw fuel or a couple other things, but he hasn't had time to work on her! I keep threatening to go take the carb off Mad Max and put it on Bella! To much longer and that is what I will do! Mad Max needs wireing work! Yuck! LOL
Good luck with yours, I hope you figure it out soon! Let me know what it was when you do!
Robert, according to the CL and Pinto.com ad it was driven daily til a couple or more months ago. The oil that was drained out was pretty dirty. The engine runs great- she doesn't even smoke at idle, just when I give her gas.
Yes it's me :P How long had she set before you got it. I assume this is the new car?
Today I changed Ruby's oil and filter, fuel filter, and positive cable clamp. I took her for a short drive to make sure all was well after a few minutes of warm-up. When I accelerate from a stop I get a blue-gray-with a touch of brown smoke billoiwing from her tailpipe. She didn't smoke previously. The oil I put in was 10-40. Too thin maybe?
