1980 PINTO for sale
Date: 06/19/2017 02:51 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Wheel cap
Date: 04/25/2022 11:21 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 05/18/2020 10:22 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
nos core support
Date: 01/03/2020 09:39 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
  • Online today: 2,567
  • Guests: 941
  • Total: 941
Question for the club
Started by Starsky and Hutch, March 22, 2010, 06:01:09 AM
thanks to everyone who gave me some incite  on  removing the knobs , guys they came off easy,, and i tapped them on the new heater control with a  rubber hammer..i used vise grips and a door panel tool and Popsicle sticks so i would`nt mark it up.....
postalpony
Hey Guys Ya' ain't pullin' hard enough!!!!
Seriously now-- 0hSix9 Is right on the money the way he says to do it.  I have just been through the same thing. The knobs fit over small indentations in the levers, over the years
the knobs get hard & doesn't want to come off--but if you be patient & work them they will
pop off.  While you have it apart this a good time to sand & paint your levers.
These will come out if you take the clip [shown in the photo] off & remove the pin.
Make a note as to how it comes apart, so you can reassemble it correctly.
               I hope this helps you solve your problem.     Dick
Now all we do is HAUL!
RSM
OhSix9
here is a pic of the 2 sets of pliers that i used to remove them. if done with care no damage comes to either the knobs or the shafts.   if you are concerned you could wrap the shaft with a little black tape before locking down on it with the vg's
OhSix'
Virgil to Sid
RSM
That's gonna be a hard one. You might be able to lock a pair of vice grips on the lever itself and use a screwdriver or something to pry the knob off. It will come off...sometimes easy sometimes not so easy. There's more than one way to skin a cat....hope this helps.
I need to use them again the new heater bezel came without them
RSM
If you don't plan on using the knobs again and have replacements, cut the old ones off. All you need to do is relive enough pressure on the knob so it will let go of the lever. I've done this several times. Cutting down the side of the knob with a hacksaw blade works but you gotta be careful. Pulling the knob off with a pair of pliers or vice grips can do a lot of damage to things you don't want to hurt. Once you get the cut down to the where the lever is you can pry it off or then use pliers or grips to remove it. Like I say I've done this several times with good results.
I don't know if i want vise grips on a nos heater bezel ,,see i have two here,, a nos 71 style all steel which i wish to sell after,, and a nos 77 style,, thats plastic and it lights up,,, which ill install in my car,,, if i get the knobs off the one thats in the car.........
OhSix9
Ok so here is what i found at the shop.  the chrome knobs on my car have the little meta tab on them that releases them.  These however may not be the original ones as nothing on the car is stock.   the other control assembly i have has black knobs which are press on and brute force is required to remove them.  easiest way is to put the control in the middle position and grip the metal lever with a pair of vice grips with a gap between them and the knob then use a pair of crimping pliers t lever against the back of the knob and the vice grips.  you can pop them off sans damage.   i did take a picture of the process if you want i can still post them up. it just takes a while as i am out in the sticks and still stuck on dial up. sorry for leading you down the garden path earlier bro.
OhSix'
Virgil to Sid
PintoMan1
1973 pinto runabout
OhSix9
i have my camera with me and am on the way to the shop. i think i have some of these off and will click a pic of the back part . will bend up a tool and click a pic of that too. i finally got the other pics of the steering coupler that someone was lookin for so i will try and post it all later this evening. stay tuned.
OhSix'
Virgil to Sid
They come off we just  need to see the tool they use
PintoMan1
i'm nut sure what to do then!
1973 pinto runabout
dont heat them off you`ll wreak them lolol there is a hole on the back of the knob someone said put a screw driver in there and pry up but that dont work when i try it...
PintoMan1
i don't know how they come off either. i was wondering the same thing. i was thinking of very carefully heating up the metal & pulling them off. i haven't tried it yet, so i am not sure if it works or not. i also don't have the metal clips in mine. i have to replace the heater switch on mine.
1973 pinto runabout
Still cant get them off!!!!!!!!! I tried a screw driver
Quote from: OhSix9 on March 22, 2010, 05:55:37 PM
use a small crude screwdriver to push in the metal tab on the back of the knob and pull forward
I dont see a metal tab on my 77 style heater controls
There is  no metal tab on mine that i can see
Chuck (discolives) has, he has chrome knobs on his heater controls. I had one of mine fall off a long time ago when I first started driving the car, I have never had it come off since though.
OhSix9
Virgil to Sid
Has anyone removed and replaced the heater control black plastic buttons ? If so how did you do this ?
