Date: 10/01/2020 02:00 pm
Date: 10/27/2018 03:30 pm
Date: 04/12/2017 08:15 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 07/08/2017 08:53 pm
Date: 02/28/2018 09:18 am
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 02/18/2017 04:41 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
  • Online today: 548
  • Guests: 191
  • Total: 191
2.3L Carb options
Started by macosxuser, March 20, 2010, 08:37:38 PM
Thank you mike!
Now, where is this power valve vacuum port and how do I clean it out?
mikerich1972
 Sorry I didn't get back here sooner!!! I obviously need to read this stuff more often...
Anyway, a clogged power valve vacuum port will give you very serious hesitation on acceleration. It will feel like you need to really step on it to get moving, then it will finally kick in.  Also, your fuel mileage will suffer quite a bit, as it will be running rich all the time. BTW: All carburetors will always fail to the rich side of operation. This is only one instance as to why that is true.
Without the proper vacuum to hold the valve CLOSED, (in the up postition) it will stay open. There is a spring that makes it a fail-open valve. This will allow fuel to flow from the bottom of the bowl... all the time. The idea of this valve is to open upon vacuum drop (as in acceleration!) to give the engine more fuel under high demand conditions only!
If you look into the bowl of your disassembled carb, you'll see the power valve (also known as the "economizer" valve) threaded into the bottom of the bowl. The vacuum-actuated plunger then drops down onto the valve, opening it in a progressive manner.
I hope this answers your question!!  :smile:
1976 Pinto Wagon 2.3L
1972 Harley Davidson FLH 1200
1972 Pontiac Firebird 350/350
2003 Ford Motorhome
2018 Ford Focus
Just curious, what are the side effects of a clogged power valve?
mikerich1972
You can get rebuild kits fo rthe carb at almost any parts store. It comes with the needed exploded views and specs inside!!
The problems I have with mine is that the economiser (power) valve vacuum port becomes clogged quite often, due to the evaporating fuel in the bowl getting up and into it. I have drilled and tapped a port into it for easy and painless cleaning.
Otherwise, a very reliable carburetor. Keep it of you can.
2003 Ford Motorhome
2018 Ford Focus
NAPA is a good source and they come with very detailed instructions as well as an exploded veiw.
macosxuser
Thanks. I haven't taken it apart and don't have manuals yet. You guys have a good source online or off for the rebuild kits? Overhaul manuals? I come from an aviation maintenance background, so I'm used to having manuals  for everything...
The 5200 is a good carb and easy to work on. Get a rebuild kit and some good carb cleaner and rebuild what you have. You can put a Holley on it but you will have to make some mods. I would keep what you have and keep it all original. My .02.  :)
macosxuser
I have an all stock '74 with a 2.3L and an auto. The carb is..... not healthy. I want to keep the car as original as practical. Is there a good rebuild solution for the stock carb, or is a different intake manifold and a holly required to get it running well? Here is a pic of the bay as it sits.
