1980 Ford AM radio
Date: 12/22/2019 11:57 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 03/30/2021 12:29 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 02/08/2018 02:26 pm
oldskool787
Date: 02/12/2017 12:42 pm
Date: 01/04/2017 04:07 am
Date: 11/04/2018 02:34 am
Date: 04/04/2020 09:38 am
  • Online today: 489
  • Guests: 222
  • Total: 222
I need negative camber
Started by Bobcat Racer, March 16, 2010, 02:17:51 PM
chevyrat65
What we really need to know for our Chumpcar 24 hour road race pinto are some front end numbers. caster, camber, toe in/out. Not stock numbers but what do people RACE with? And yeah that car looks NIIIIICCCEEEE :hypno:
kneescraper
That is a DAMN nice car!!!! :drunk:
375instroke
What about just slotting the rear, and gaining more positive caster, thus giving more static camber gain, both negative on the outside, and positive on the inside tires?  The car I just got was set up for circle track, and the right upper control arm was cut and welded shorter for left turns only.  That's going to be changed for our road race endeavors.
wingman72
If you are going to lower the front end either by shortening the stock springs or installing shorter aftermarket springs you might not have to do any mods.  I'm running 2DEG Neg camber and all we had to do was slide the upper control arms in and align it.  My 2 cents.
KCREGION SCCA MEMBER
2nd place Mid Am Championship 2000,2001, 1st place 2008
Bobcat Racer
Thanks everyone for all of the advice.  I had an idea of how I was going to achieve neg camber but I wanted to hear from those with experience and more know how than me.  I'll likely be asking more questions as we continue on through the build and I'll post pics after we get the floor repaired, motor installed, and off of the jack stands.
Thanks again!
In case you have not seen the FAQ suspension thread, see link below.  77TurboPinto mentions moving the lower control arm inner mount point up 3/4" to improve roll center.  I believe this would also increase the camber gain some.  If this is correct, maybe you would not need so much static negative camber.  Notice all the if's and maybe's above, I have not tried any of this and am not a racer.
http://www.fordpinto.com/index.php/topic,7913.msg46713.html#msg46713
Have fun at the LeMons.
Mike Modified
Some racers turn the upper a-arm shaft 90*, weld a large piece of angle inboard on the top of the spring cap (far enough in to give you more camber than you want), drill it so that the shaft bolts to it, then use normal u-shaped shims to get the alignment you want.
Clear as mud, right?   :o
1/2" extra in the slots will give you about 2 to 21/2 deg negative camber.
Bobcat Racer
Thanks very much for the instructions.  I rescued this old Bobcat from going to the crusher and I'm building it into a 24 Hour of LeMons car.  I think the 2.3 is bulletproof enough to go the distance and we are stripping every bit of weight we can out of the car but we need it to handle well.
You will need to remove the upper control arms first. Then you will need to move the adjustment slots inboard about 1/2". The best way is with a right angle die grinder and a carbide cutter. All four(4) of the slots must be moved, and it does take time. The material there is several layers thick and there is no easy way to do this. Is this an autocross car or scca road racer? LOL.
Bobcat Racer
To all of you Pinto racers out there, i'm setting up my Bobcat to road race and wanted to find out the best and cheapest way to get negative camber.  What tricks have you guys used to accomplish this?
Thanks in advance for any help you can provide.
