71-73 Hood
Date: 12/07/2018 06:22 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 07/04/2022 07:55 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Date: 01/04/2017 04:07 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 447
  • Guests: 213
  • Total: 213
Pnto no start condition
Started by r4pinto, December 29, 2004, 08:38:24 PM
In that case I'm in good shape as before the ignition parts replacement the car had a top speed of maybe 45-50 mph. Now with new ignition parts it goes much faster than that... and on a blown motor too. ;D
CHEAPRACER
My advice would to be get it running right, providing the oil fouling will let you, and get it starting right. That way when you pull your running combination and put the new rebuild in, it will also run and you will only have to worry about oil & water leaks upon startup.
Well, the problem I had is that the car was in storage and I couldn't get the car started at all to get it anywhere to swap the motor. Once I changed the ignition components on it the car fired right up... The distributor parts I bought though, are in the distributor that I rebuilt for the new motor. I actually got that in the new motor right now... just sitting in there, but none the less out of danger from getting damaged just sitting around. At this point the whole ignition system is new & ready for the swap... All I need now is an exhaust manifold, which I'm going after tomorrow, fuel, & water pump, and engine block painted, as well as a gasket set for the engine... Not much to do before swapping engines, but enough...
Thanx for the advice though... I will keep the ohio Pinto owners in mind though, when I go to swap the engine. :)
Quote from: Farmboy on January 07, 2005, 04:35:23 PM
Hey Matt, with all the problems with your engine over the last 4 to 5 mo. I would just set aside a weekend and do a motor swap, no sence in putting more money into a motor your just gonna throw away. This is my 2 cents on your problem. With all the pinto lovers you have in Ohio it should not be any problem trading work on yours for work there cars. How cold is it back there, Burrrrrrrrr
I concur with farmboy, great advise.
Farmboy
74 Pinto Wagon
71 Runabout (parts car)
Well, I think the plugs were getting fouled out becuase there wasn't enough voltage to burn away the oil that was entering the cylinder. I have a motor I'm gonna be installing in the car, but until then whatever I do is just gonna be a band aid fix so I can drive the car from time to time. :)
cool, but you still need to fix the oil fouling issue????
OK... I ended up having more problems, as the car was only on 2 cylinders.. Threw a set of clean plugs & ignition coil at the car & it ran good.
well I hooked a timing light to the #1 spark plug wire & was getting spark, so no problem there. After all this investigating & still nothing I pulled the #4 plug... oil fouled... went to #3 same thing... I'm not even gonna pull #2 or 1 as they are prolly gonna be the same thing. With that I'm gonna put a hotter plug in there for now until I get the motor pulled. Atleast that should hopefully keep my car mobile.
Thanx guys for all your help.
econoaddict
to check and see if coil is sparking just lay the dist end of the coil wire near a ground and watch while cranking, hopefully you see spark.
If it is burning oil badly the problem could be as simple as your spark plugs being oil fouled and not creating sufficient spark to ignite the fuel mixture.
'75 pinto very soon to have
302, C4, maverick rear
CHEAPRACER
Take the cap off the distributer and turn the engine over to make sure it's turning and your timing belt didn't rip it's teeth off. I just saw the same thing happen to a Honda Civic.
well today I got to my Pinto to take it out of storage so I can work on it while off, and went to start it, but it didn't. I could get it to turn over, but no fire.. I thought it was low on fuel, so I sprayed some starter fluid in it to help start it, but nothing. I shook the car & it does have gas in the tank.  Regardless when I sprayed the starter spray in the carb it didn't even try to fire up.
I drove the car to it's current place a couple weeks ago and it was running ok, considering it's badly burning oil, but now nothing.
I did take the ignition module/ box to Advance Auto Parts & it did test good, but now I need to know how to check the coil. What's the easiest way to do this on this car?
Thanx for any help.
