SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
pintos for sale
Date: 12/11/2018 04:29 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 08/06/2021 02:23 pm
Date: 10/04/2019 08:43 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
  • Online today: 119
  • Guests: 55
  • Total: 55
Replacement ball joint boots
Started by 1978Pinto, February 13, 2010, 02:02:08 PM
1978Pinto
Suspension.com sells replacement ball joint boots, part # 13009 & 13024.
I cut the original boots at the base with a single edge blade.
The boots were shot, my ball joints are still good.
Jerry
1978Pinto
I ordered some ball joint boots from suspension.com in Modesto California today.
I will report again after I receive and install the boots with the correct part #'s.
Does Mustang II use the same A-arms and ball joints as Pintos?
Thanks, Jerry
If you are still on your stock ball joints, you will have to replace them. I had the same problem with my passenger's side ball joint and I ended up having to replace it. I opted to change them all out.
The reason being, they are riveted into place from the factory. Once you cut the rivets, there is virtually no way to put the back on. I suppose you COULD drill out the remaining rivets and use bolts, but why not just replace them all at once?
1978Pinto
Jerry
