71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 06/07/2018 01:45 am
Date: 07/04/2017 03:26 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 02/21/2022 11:11 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 403
  • Guests: 178
  • Total: 178
driveshaft length
Started by pintoracer02, January 02, 2010, 03:09:52 AM
I believe the correct length is 45.5"
  Just so happens a:
1973, C-4 behind a 2000 with an original 6-3/4" rear worked perfectly with a ---,
T-5 behind a Turbo 2.3 with a Mustang II, 8".
One of the easier things on my 2.3 Turbo/T-5 swap. Slide in the yoke and tighten the four U-bolt nuts.  :smile:
I mention the applications because I had heard different trans/rearend configurations had different length shafts.  The possiblity exists that just getting any shaft from a certain car might not fit.  And even here I'm assuming the T-5 will mount in the same location regardless of the engine being a V-8 or an inline 4.
Tom
pintoracer02
Thanks for the help. This is the first v8 swap i've done in a pinto. I know where a couple of fox driveshafts are so that should be know big deal.
Bass Ackwards
I used a aluminum shaft for a Fox body mustang worked  perfect. I have never had any luck with steel shafts when you start making power. Used to bend them every week end.
pintoracer02
does anyone know off hand what length driveshaft is required for a v8 swap with t5 trans and 8" mustangII rear axle? Will the 4 cyl driveshaft hold up to this set up if i have it cut and shortened?
Bass Ackwards
