Date: 10/27/2018 03:30 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 10/25/2019 03:30 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 02/08/2018 02:26 pm
Date: 02/11/2020 12:09 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
  • Online today: 367
  • Guests: 193
  • Total: 193
white crystals
Started by 1repuwannabe, December 02, 2004, 03:52:37 PM
Ok just to get all "techincal" on ya, it's "electrolosis" the reaction between two dissmilar metals. In this case iron oxide(rust, most likely from your tank & lines) & aluminum. the two metals actually create electricity that breaks down the metal at the molecular level. My carb looks like a crackhouse mirror inside about once a year. :P
Yep, it will allmost allways happen with Aluminum.
1repuwannabe
this "corrosion" is or was in the float bowl. I do not know what they look like after they dry . but when I pulled some onto my fingertip they looked like the shaving from rotor turning attracted to a magnet
1repuwannabe
It is corrosion, and what causes that is the moisture in the air that goes through the carb corrodes the aluminum. I've seen it all the time on the bead of aluminum wheels.
not 100% sure, but i think it happens when different metals (aluminum and steel) are in contact with eachother.
1repuwannabe
corrosion?? from what? how do I find the culprit?? what do I use to flush the system??
it's corrosion, you'll see it at the legs of the seats in older cars.
1repuwannabe
has anyone ever seen white crystal like substance in thier carbs before?? i saw this after taking off the top of my carb to adjust the float level. the cryatl look a little fiberglass pieces.
