Date: 07/20/2017 01:23 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Date: 02/18/2017 04:41 pm
Date: 06/07/2018 01:45 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 08/16/2018 08:54 am
Date: 12/26/2016 04:29 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
  • Online today: 899
  • Guests: 456
  • Total: 456
What's the easiest swap?
Started by SageNip, November 27, 2004, 02:08:44 PM
SageNip
Hey Bricker... you still want that "stock" Offy?  Is it for a 2.3?  Would you consider selling it?  Trade?  Gimme a shout!
Blacksmith, weldor, sculptor, 8 track collector, Pinto enthusiast, retired sideshow performer, manipulator of flesh and steel.... keep your ponies warm.
bricker4864
The manifold on the right is the stock 0ffy. It's a dual plane that someone spent a hell of a lot of time making a casting for. On the left is the manifold I "customized." It's no longer a dual plane, it's injected!
bricker4864
Quote
I have a straight piped no cat Hooker header exhaust system. Should I mill the head? Grind the cam? How about a 4 barrel carb? What are my options to give my pony some more kick? She already is pulling 0-60 times around 9 seconds (maybe less).
Putting a on a header made the biggest difference in my car. I put on a Holley 390 with an offy manifold. That got me a mph or two at the track, but made it a piece of shizod to drive on the street. I ground out the guts of the manifold and it ran a few tenths quicker, but that's a lot of carb for a street car = really touchy and hard to tune. I did put in a cam and an adjustable gear that also got me a little quicker.
The top three things I did to make my car go faster were:
- Drain all of the water out of my gas tank. ;D
- Replace the entire exhaust system.
- Put in a set of low gears.
I run spooled 4.62s in an 8". While that's a bit to much for most people, it sure as hell gets you from one side of an intersection to the other pretty damn quick.
I'm interested in this too Sagenip. i'm getting around 8-9sec 0-60, but in the neighborhood of .85g on the skidpad! (I love R-spec rubber!!)
SageNip
Okay, I get it now.  This is what I was trying to avoid, but it seems that a V-8 Pinto is out of the question for me.  I don't have the time, tools or money to do it.  Now here's my follow up question:  I have a straight piped no cat Hooker header exhaust system.  Should I mill the head?  Grind the cam?  How about a 4 barrell carb?  What are my options to give my pony some more kick?  She already is pulling 0-60 times around 9 seconds (maybe less).
Thanks,
Sage
kris kincaid
Crazyhorse hit the nail on the head when he used the word shred. Your non V8 transmission will not bolt up to a 302. The bellhousing is completely different. Maybe you could adapt it, but why bother? The input shaft is puny and so is the gear set. I have never tried it, but I imagine a T5 from a 5.0 Mustang would fit nice. It has a cable operated clutch, so figuring out how to actuate the clutch wouldn’t be an issue. When I built my car, I used a C4 with a small bellhousing and flexplate. I believe it was a 157 tooth flexplate, but I am uncertain. I found the trans on the ground at a recycle yard! Even with this combo I still had to pound out the trans tunnel for clearance. I didn’t like doing that, but now I find out pretty much all V8 Pinto’s required this.
As for the rearend, I just trashed the original 4 cylinder unit. In its place I used a 9”. That was overkill, but I never had to worry about it failing on me. I would use an 8” if I was to do it again. For 8” info, there is no way I could top Brad’s excellent thread on these diffs:
http://www.fordpinto.com/smf/index.php?topic=953.0
Here is a website that pretty much lays out what needs to happen when doing a V8 Pinto. I won't even try to top it either! :
http://www.geocities.com/g_wellwood/automotive/v8pinto.html
ganar dinero a espuertas
Dont get me started on what I think about stock auto trans behind any kind of built V8................. >:(
SageNip
See that's what I was trying to avoid: replacing the entire drivetrain.  I'd have to get a better tranny, driveshaft, and rear.  Is all this REALLY necessary?
it may bolt up, but a V8 will SHRED the 4spd tranny from a 4cyl
SageNip
Okay, I was told that the 289 or the 302 will mate up to my standard tranny on my Pinto wagon (2.3L).  Is this right?  If so, will ANY 302 fit?  There's a F-150 on the lot with a EFI 5.0 motor that I could use.  What's the easiest swap that can be done if I want a V-8 in the wagon?
Thanks,
Sage
