1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 01/30/2017 01:48 pm
Date: 04/06/2017 12:13 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 08/13/2018 02:46 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 02/28/2018 09:18 am
  • Online today: 2,567
  • Guests: 375
  • Total: 375
2300 stock cam spec.
Started by old pinto, December 06, 2009, 10:55:51 PM
I did the swap on my 78's 2.3 this year. No difference aside from the thing starting a bit easier and the engine running a wee bit smoother. Wasn't sure if I was supposed to notice anything different though.
Dave, apart from the roller being more efficent I'm not sure if there is a noticeable gain in power. I know I have read on here of others doing the swap, maybe do a search and send a PM?
Thanks! What impact is made when swapping the the two cams, if any? Would it be noticeable?
Quote from: dave1987 on December 07, 2009, 11:04:36 PM
How about the stock lift on a Mustang roller cam? Or the ranger roller cams? If you swap the stock pinto cam for a roller cam, are you retaining the same specs?
.390 for the roller
old pinto
Quote from: 71pintoracer on December 07, 2009, 08:22:09 PM
The stock lift is .399, I don't have any duration specs but I do know that the Merkur and T/C turbo cams have different duration specs.
Great that helps. trying to get a base line to work off of for engine mod. going to be a street car with carb.
old pinto
Quote from: Mike Modified on December 06, 2009, 11:09:59 PM
No stock specs, specifically, but a lot of info here: http://www.merkurencyclopedia.com/.  Click on "Cams" in the left-hand menu.  It seems to me that the Ranger cam is very similar to the Pinto cam.
Rick Byrnes is a Ford engineer who raced (drag and land speed) a Merkur, eventually setting a record for "production class" of over 200 mph at Bonneville.
just checked out the site you recommened. Lot of info. Many ideas when it comes to putting a motor togather. Thanks for the reply,
Mike Modified
old pinto
can anybody give me stock cam spec. for a 2300. 1974 for info. would like to know for a base line on starting some engine mods.
