Squire trim
Date: 03/28/2018 10:11 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 04/06/2017 12:13 am
Date: 02/03/2018 11:28 am
Date: 02/18/2017 05:55 pm
Date: 10/28/2018 08:45 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Date: 08/08/2017 01:44 pm
Date: 06/24/2020 06:12 am
  • Online today: 1,090
  • Guests: 138
  • Total: 138
Does anyone have the instructions for removing a 77 front signal light lens/pot
Started by Starsky and Hutch, November 28, 2009, 09:04:45 AM
78txpony
It is not the easiest to do on 77 & 78 models.  :-\
It all comes off as a big assembly. OR, you might be able to just loosen it all up enough to replace what you need to.
After the visible brackets are off from behind, the whole rubber piece around the headlight must be pulled.  There are 4 nuts behind the headlight - a 7/16" or 1/2" deep socket, a u-joint, and several extensions must be used. Lay on a rug under the car.  There are a couple nuts at the lower fender, too.  Careful at pulling the rubber  from the paint, as they stick together sometimes. And YES, the paint will crack if flexed too much - work carefully.
Are your inner white parking lamp shells broke?  Mine are all busted up from wrecks 20 years ago and need replacement.  The bulbs just kinda lay there.  :o  However, it is not bad enough to render all that dissassembly...  :nocool:
-Rob Young
1997 H-D Sportster
Quote from: pintoguy77 on December 04, 2009, 07:38:50 PM
Thats really easy ,i took mine out after removing the 4 screws that hold it in.It just slides out after the screws are removed.
I cant flex that urathane frame at all paint may crack
pintoguy77
If someone has this manual on the 77,Can you please email me the info for: signal light  replacement,, front drivers side,,1977 pinto sedan
