Date: 03/07/2017 07:03 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 10/11/2019 11:13 am
parting out 1975 & 80 pintos
Date: 10/31/2018 12:00 pm
Date: 11/29/2018 10:26 am
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 09/01/2017 11:58 am
  • Online today: 1,438
  • Guests: 136
  • Total: 136
carbbed turbo
Started by 80bobcat, November 16, 2004, 04:37:40 AM
Quote from: SVOwagon on December 09, 2004, 06:25:07 PM
I have never done this... but I would think no. Why do you ask?  I've never delt with any other harness other then the Merkur and 87-88 T/C. I'm about 90% sure you can't with these two because the 87-88 T/C has an extra senser in it, so the wires would not match up. As for the 83-86 T/C harness, I guess first you could look to see if they would physically go togeather. Then you would have to look at the pin out sheet ( on my site ) and see if all the sensers have the same pin out numbers. Then it should work.  If they DO have different numbers, I guess you could move them to get it to work. I would just use the right "sub" harness and not have to worry about it.
I asked because I know I have the complete subharness out of my 86 t-bird but I am not sure if I got the rest of the main harness I needed.  I ran out of time and had to get rid of the car sooner than I had hoped and had to rush to get the computer and wiring out before the next owner came to get the car.
I for one would like you to post some more pics of your car, primairly the wiring.  I have hesitated converting my car to fuel injection because of the wiring harness but it sounds like it will be much easier than I thought.  I will most likely do the conversion this coming summer.
Thanks for your help
SVOwagon
Glad to hear you FINALLY got the harness out...just kidding ,man ;)   If you need or would like, I'm going to my parents for Christmas ( that is where I'm storing the wagon for winter) and could snap some pics of it. This is the only time I can do it till Easter, so ask now. ;D
SVOwagon
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
80bobcat
 ;D ;D ;D found my point of confusion..once i removed the alt. harness from the starter relay..the rest of the harness fell away..I now have the engine harness with puter....whew ...the `75  bobcat was a no go for me.
Look Officer..it`s a Pinto would YOU stop short?
80bobcat
K..I`ve been avoiding this long enough..read and reread your post.. looked at and studied your pics...I think I`ve made a mountain out of this..( got everything taken apart and cleaned and sent the block & head out for checking,cleaning)...so i got myself all the way to the left side to where it re-enters the cabin and i`m not supposed to be that far. the sub harness was to end earlier than that. So  my next step is to start taking the wires apart and get this sub-harness out..I have no need to re-enter the cabin? I noticed you used the Pinto starter relay..the lower cable on the throttle..kick down linkage?   And the only wires entering the Pinto is for the puter..right?        Other stuff....Daughter doesn`t want to give up the Bobcat now..says the car grew on her..Yaa right.. she`s broke and its a guy magnet..and I was born yesterday.. ;D  Anyways found a `75 Bobcat..may go look at it this weekend...5 hrs round trip..put the turbo in the better of the 2 and she can use the other for school..but the added costs will slow me up some.
SVOwagon
83 Ranger
Quote from: SVOwagon on December 06, 2004, 06:53:04 PM
none...The EFI harness will be all by it self. There will be one wire that will go to your battery side of the starter solenoid and one wire that will go right to your negitive post on your battery.
Wow, that is easier than I thought ;D  One more question...  Can you mix match harnesses?  In one of your previous posts, you mentioned the sub harness that splits off from the firewall.  Can you interchange that harness between the T-bird and Merkur?
SVOwagon
83 Ranger
Ive been following this thread for future reference...  What wires need to splice into the original Pinto harness?
SVOwagon
I used my Pinto alt. so I really don't know anything about the Merkur alt. set-up. You can reuse your Pinto alt. and wiring, but may have to change pullies if your not going to use the V-belt set-up.
83 Ranger
80bobcat
SVO..you`ve helped tremendously..thanks..your site..well i`ve been referring to it all along..great site and nice job on the car(your site has been in my fav.`s since I first entertained the idea of a swap)..anyways the harness has been stripped of the extra`s and i`m as far as where it enters on the left(drivers side is always the left side) there is a small l/blue wire off the alt. any idea what its for?..anything else you can remember will help but for now i need a rest.... ;D
SVOwagon
EEC-IV...yes, this is the right computer. By the way, heres my site.
http://myweb.cableone.net/svowagon/
83 Ranger
SVOwagon
Ok, this may help. Go onto my site, go down to "other turbo Pintos", then click on "High Performance Pinto". Go down to the very bottom of this page and there are some really good pics of his engine bay. Looks to me like all the wires you need are the ones in the red loom. You can also click on the 4 cornered arrow thingy in the bottom right corner of the pics to super size it. You can see where the red loom goes into the firewall. This will be in the same place as the Merkur, only the Merkur will have a grommet around it. Facing the engine bay on your left side...you will need wires that go to the VAM, boost solenoid, ground wire that goes to turbo housing, MAP senser (black thing held on by 2 bolts),and  there will also be 2 plugs (one small, one big) that will not go to anything. These are the plugs for running codes for your sensers. Don't worry about them right now. You can see that the harness kind of splits into two parts from the fire wall. One goes to the things I just described, the other goes across the back of the engine bay. Follow this one and there will be a wire that goes to the battery side of your starter soleniod and one for the EGO senser (on top of the exhaust elbow). Follow it along more and there will be a plug that goes to your TPS. This is on the side of the throttle body. There will be another plug that goes to your air bypass valve (big round thing right next to the throttlebody). Following it along more and the harness will split again. There will be kind of like a "sub" harness that will have wires going to your 4 injectors; oil psi senser, coolant senser, knock senser, ACT senser (middle of intake), I think that may be it. This "sub" harness you can't see in the pic, and you may have left it on the engine when you pulled it, as it does unplug from the main harness. This is what I did.  Moving on down tha MAIN harness, we come to the EGR shut off senser. Then to the coil and on to the TFI (on the side of the distributor).
   I wish I could take detailed pics of my car for you, but it is in storage 320 miles away. As for the inside, what I wrote before is all I can really remember for now.  I hope I didn't leave anything out in the above paragraph...78pinto ??? ???
83 Ranger
80bobcat
ooops...I started at the gromett on the right firewall...was i to separate the harness at that point and only take the engine stuff?...that box marked EEC-IV is that the right puter? cause I see more under the dash.
SVOwagon
Wires to the marker lights ??? ???   Sounds like your getting too many wires. There is a harness for the engine and one for the body. You only need the harness for the engine. Like I stated before, start at that grommet above the turbo, and work your way out to all the sensers, then inside to the computer. Anything that is not involved with this harness you do not need.
83 Ranger
80bobcat
update.......k got the harness to the EEC-IV out all along the right side across the front and down the left to the brake booster now from there it looks like I`m going back into the cabin after i get it out from around the booster..sound right?only cut 2 wires..to the 2 side marker lights also found a few eyelets loose but figure the`re grounds...passing thoughts as I`m working......everyone says the turbo engine is an easy drop in for the Pinto..then it dawned on me not one word about the wiring  ;D and I gotta stop manhandling this stuff..broke a couple of vacumn fittings along the way :'(..hoping to rebuild the engine over the holidays but can`t get to it till the car is out of the garage and won`t do that till the harness is out.
not a chance!.....besides SVOwagon has this covered, thank god! ;D
losin sux
Hhhhhheeeeeeyyyyy JJJJJEEEEEEFFFFFFFFF they are talking about wiring here......your FAVORITE subject!!!!!  Jump in here and help this guy out.  You have experience doing this not ONCE but TWICE on the same car.  lol
77 HB 2.3 C3 3.40
SVOwagon
I got my harness from a Merkur. This is what you should do. On the passenger side under the hood find where the harness goes into the fire wall. This will be right above the turbo. Follow it out to the engine and to all the sensers. Go inside and follow the harness to the computer. It will be somewhere by the kick panel. Also, there will be a bunch of grounds going to the body in this area as well. Unscrew the computer from the harness and unbolt the grounds from the body. There will be other wires to undo, but it's been awhile and can't remember everything. After it is all loose, with a screwdriver work your way around the rubber grommet (from under the hood) that is in the fire wall around the harness and pull everything to the engine bay. Look for things in the engine bay that might be bolted to the body... sensers, grounds or anything else that will have to go with the harness. I know I'm leaving things out but it's been awhile and can't really think of everything right now. One thing to always keep in mind...DO NOT cut any wires!!!
83 Ranger
pintoman
The computer on a merc. is hidden on top of the clove box.Or could be in the passenger kick panel.
80bobcat
thanks people...now under the hood left side by the w/s  is a box of relays fuses etc..I`ll assume thats coming with the harness..the rest of the harness (to the puter?) looks like it enters on the right side..and what looks like a vacumn aplifier..also i`ll assume any vacumn lines entering the cabin is to control the hvac...not engine mang....went looking for a haynes manuel but most if not all places discontinued carring them on the merkur got one on the t/c though..my niehbour says I`m suffering from midlife crazies..he can help with the engine rebuild but I`m on my own for the wiring...well not really..I got FORDPINTO.COM........lol.. ;D
Ok there'll be a BIG wad of wires with a rubber grommet like six inches long. one end will have most of your engine sensors , the other will have the 'puter. My Taurus's is actually on the firewall behind the heater!! That means I've gotta pull the WHOLE dash to get to it.
svoman2300
I know on a Mustang you have to remove the dash to get the harness out. I would assume you have to do the same for the Merk. Also your best bet would be to find a large Vam from a SVO or 87-88 Tbird , 35lb. injectors and the computer needed to run them. You don't have to do this, but you will have more HP if you do. You can find most of these parts on Turboford.org.
84 Mustang SVO
81 AMC Eagle
80bobcat
update...engine out and sitting on stand waiting for time and money...now what do i do about the harness?..I only pulled what i had to off the engine and marked them..but what about the rest of the harness.. ??? and the puter..I`ve scoured the car and for the life of me can`t find a keyboard or mouse..(figured I`d follow the wires back to the puter) ;D..k I admit I`m a jughead not a wrench head..need help on what to take...and how?..I`ve removed most clips holding the harness under the hood but do i need it all?..headlights..etc? Do I trace back what I need and remove them individually?......thanks for any all help!!..think I`ll go read or clean parts till I start step 2....lol..
80bobcat
Thanks all...got the 87 merkur home yesterday....now the fun begins....I just gotta keep looking at it 1 step at a time cause the whole picture is a little (a lot) intimidating  ??? and reading about the swap is my way to avoid doing it...lol.....lets see now...step 1 ..go read some more........ ;D
Quote from: SVOwagon on November 22, 2004, 07:48:55 PM
Get the engine and computer from the 88 T/C and the harness from the Merkur. Your set!! ;D
SVOwagon
I concur doctor............. ;D
SVOwagon
SVOwagon
83 Ranger
80bobcat
Went  and looked at the 86 t/c the guy had started to take it apart and the engine bay looked like a rats nest ..so I kept looking and found a 87 merkur and another 88t/c...I figured they`re all going for about the same price so why not look at them all...3 weeks ago I couldn`t dig up a 2.3 turbo and now i found 3 in a week ;D.....go figure!!...
pintoman
Yes the Mercur motor will bolt up to your C-4.
SVOwagon
Merkur?? What happened to the 86 T/C?? If you do decide to start on a EFI turbo swap, there are many guys here that will be willing to help.
SVOwagon
83 Ranger
80bobcat
Sorry people.....the real Q is will a Merkur 2.3 turbo with a 5 spd bolt up ...to my auto C4?
