FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 02/25/2017 08:45 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
Looking for front seats
Date: 08/10/2021 09:54 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
SVO SWAP
Date: 03/15/2018 03:12 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
  • Online today: 449
  • Guests: 301
  • Total: 301
What size tires with Mustang Turbine wheels?
Started by svoman2300, November 08, 2004, 11:47:59 AM
pintoman
I'm running 225x55x15 on the front and rear using 83 Saleen wheels that are 15x7.I don't have any clearance problems at all.And with no spacers.
pinto_chris
I forgot to add that the car has some very bad bump steer now, and though they look cool on it, I'd just run them on the back if i had to do it again
1973 ford pinto wagon
1966 amc rambler
1985 Mercedes 300 D, powered by used vegtable oil.
  hey I like being different! stop laughing now damn it or I'll sick the penguins on you !
pinto_chris
i have a set on my 1980 and i have 225/60 in back and 205/65 in the front but thats with removal of the inner fender and some hitting with a hammer in so places for clearance and 1/4 spacars in front.
1966 amc rambler
svoman2300
I only put the rears on. I haven't got to the fronts. I figured I would need  almost a 1/2" spacer to make the fronts work. I will try to get a pic by the weekend but I won't promise anything because I have to get my girlfriend's camera from her.
Rick
84 Mustang SVO
81 AMC Eagle
V6 Cat
Hey SVOman, you have any pics of these wheels themselves or even pics of them on the car? Thanks a lot! Rahn
svoman2300
I haven't measured the backset however I installed them on the rear with 225/60's without any problems. As ugly as I've always thought those wheels were, they actually look good on the Pinto. I put a wheel only on the front to see if it will fit and it barely touches the A arm when at full turn. I am going to get some spacers and see how it clears and if it works out I'll get some longer studs and install those.
84 Mustang SVO
81 AMC Eagle
wagonmaster
Because of the above mentioned backspacing, the wheels will need to be installed with the spacers. The one area to watch for is clearance to the upper control arm. With stock Mustang alloy wheels, the arms may have to be trimmed slightly. I am using '86 Mustang Police Special 15x7 steel wheels which are thinner than the alloys so I didn't have to trim the control arms. Don't get too carried away, though, because it could weaken the control arms beyond what is safe. I have used 205/50x15 tires on the front with the Mustang steel rims without any issues at all. I am running 225/50x15 on the rear, but a 245/50x15 should fit without any problems at all.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
Those wheels have a 5" backset. Im not even sure if they will work on the front.  ???
Rick, I have 205/50/15's on my 73 HB.  However the wheels are Centerlines instead of the turbines.  I can't comment on the spacers as the early cars use a different offset wheel.
svoman2300
I searched but couldn't find what I was looking for. I picked up some Turbines for $20 for the Pinto. Do any of you guys have any recommendations for tire sizes? I read on TurboFord 205/50  for the front with 5/16" spacers. But couldn't find a whole lot of info here.
Thanks
Rick
84 Mustang SVO
81 AMC Eagle
