99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 05/18/2020 10:22 pm
Date: 09/26/2019 05:31 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 12/15/2018 02:21 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Total Topics: 16,268
  • Online today: 329
  • Guests: 294
  • Total: 294
emmissions equipment
Started by Jimmyfrank, October 06, 2009, 09:08:23 PM
I believe the thermactor is the smog pump, usually located on the left side if you're facing the front of the car. If you're in Cali, then I think you have to have it hooked up. I'm not sure of other states. If it's smog exempt then probably it's not necessary. The other vacuum lines probably should be hooked up for better performance.
Jimmyfrank
Hi.  I have a 76' pinto wagon with the v-6 and automatic transmission. I intend to use it for mostly off road usage around my ranch and let my kids drive it on my property.  It runs kinda crummy, pops back on cold start up and seems like it has a miss.  Much of the emissions tubing and fittings are missing or broken, and some of the emission stuff that is intended to be triggered electrically doesn't seemed to be hooked up.  Doing some reading, it seems there's supposed to be two vacuum advance hook-ups to the distributor and there's not.  Could this be part of the rough running problem. There's so much vacuum stuff on this engine it's incredible.
How much of it can I remove and not hurt normal performance? How do I know what to remove? What the heck is a thermactor and do I need to keep it?
Help will be appreciated.
