Date: 07/08/2017 08:53 pm
Date: 04/15/2017 05:14 pm
convert to stick
Date: 05/19/2018 09:26 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 03/29/2019 07:20 am
Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 12/09/2018 06:59 am
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
  • Total Topics: 16,268
  • Online today: 648
  • Guests: 288
  • Total: 288
Will this all work??
Started by lefty, September 20, 2009, 08:26:27 PM
lefty
Well that leaves me out--a mechanic to that extent no way--I appreciate your filling me in on the degree of difficulty-
thanks again
Lefty
Quote from: turbo74pinto on September 21, 2009, 04:01:21 PM
from the ranger youd need:  2300 engine, 4r44e tranny (computer controlled), engine control module, engine/tranny harness and drive shaft yoke.
what else youd need:  high pressure/volume fuel pump, a way for the ecm to read the speed of the vehicle for shift points (thats IF the vss is on the rear axle, which im pretty sure it is on those rangers),  IF the vss is on the tranny (which, like i just stated, i dont think it is) youll need to find an alternative way to read your speed from inside the car ,a wiring diagram for your pinto and the ranger for wire splices, and your drive shaft modified. im pretty sure that tranny is longer.
id still keep that ranger around until i had the pinto running good.  its easy to overlook stuff.
as far as your "can i install this" question, the answer is yes.  it just depends on how much work, patience and smarts your willing to put into it.  this is a very simaler swap id like to do...but with a 2.5.  i think it would be a great cruiser.
bob
turbo74pinto
bob
lefty
I found a 1997 Ford Ranger truck with the 2.3 and automatic-has 75,000 miles on the engine and transmission--guy wants 500.00 for the truck--QUESTION CAN I INSTALL THE ENGINE AND TRANNY IN MY 1977 PINTO AND IF SO JUST WHAT WILL I NEED FROM THE DONOR TRUCK OTHER THAN ENGINE AND TRANSMISSION..
THANKS IN ADVANCE
Lefty
