1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Oddsnends
Date: 12/20/2016 10:52 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 12/31/2017 11:14 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 07/13/2018 02:21 pm
  • Online today: 548
  • Guests: 327
  • Total: 327
72' 2.0 timing specs
Started by Daniel C, September 04, 2009, 04:18:31 PM
Try 10* BTDC. If it pings on a pull, back it down 2* at a time. I think the spec is 6*BTDC but it will run better at 10.
1. Mark the notch in the crank pulley w/ white paint or white out and find the 10 on the timing scale and mark it.
2.Start the engine and let it warm up so the choke is off and it is at base idle. Turn the engine off.
3. Unhook and plug the vacuum hose on the distributor, slightly loosen the dist bolt, and hook up the timing light.
4. Restart the engine and move the dist until the marks line up. Snug the dist bolt and recheck the timing. Hook up the vacuum hose and take it for a spin!  :fastcar:
Daniel C
Hi, I'm new to pintos, and was wondering what the timing specs were and what the recommended procedure is to adjust the timing.
I've got a 72' it's a 2.0, the in-line 4, OHC...
The timing is off, and I don't have a manual yet, so any input would be awesome! Thanks.
