Date: 03/06/2017 01:24 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 03/17/2019 03:57 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 08/30/2021 03:20 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
pinto for sale
Date: 09/11/2016 09:47 pm
  • Total Topics: 16,268
  • Online today: 673
  • Guests: 250
  • Total: 250
engine swap
Started by blupinto, August 19, 2009, 08:03:45 PM
I just put a 85 t-bird turbo long block in my 75.  You will need the oil pan, front oil pickup and i would reccomend replacing the oil pump with a mellings, i believe is a M125. Gives me great oil pressure without being crazy about it.  Other than that i don't recall anything else major.
yes any rear wheel drive 2.3  will fit  mount wise. you would have to change the oil sump pump and pan  and probaly didpstick. and maybe a few other  parts. but the block is the same.
Yes, it'll be a '71-'74 2.0 that has had work done on it (for the good) and I'm paying very little for it. I would have to pay hundreds for another 2.3 and that won't happen for a while, otherwise I would. Also, just out of curiosity... would a later 2.3 still deliver that distinctive "Pinto" sound (like a soft growling purr)? Or is that the muffler that creates that? Also- would a newer 2.3 fit motormount-wise into mine? Thank you JT for your recommendations. In the end I may end up doing what you suggest.
72pair
Blu, the main obstacle will be engine/frame mounts--they are different between the 2 engines.  I assume you are considering the 71-74 2.0 not the 80's ranger 2.0. The radiator should work fine, but you'd need 2.0 accesssory brackets and such. As much as I love the sound of a 2000cc, I would look for a good  later model 2.3 and swap on pinto specific parts(oilpan, manifolds, alt & ac brackets). Much, much simpler! Keep posting with your decision. Best luck, JT
Hi folks! This has probably been brought up earlier but my computer's browser is so very slow I don't have the patience to look (5 + minutes for a page to load!?!) so I hope I don't frustrate anyone...
I am possibly getting a 2.0 engine in the near future and what I'm wondering is is it possible to swap the poor dead (or almost dead) 2.3 out of my '74 that has smog pump, a/c and other gewgaws? I know my '72 had automatic C4 tranny and Wildfire (the '74) has a C4 too. I know it'll need a new (different) radiator but is this as simple as it sounds? Thank you.  ;D
