Date: 10/24/2019 01:43 pm
Date: 12/09/2016 08:34 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 03/14/2020 01:52 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 06/22/2017 07:19 am
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 09/19/2019 04:43 pm
  • Online today: 452
  • Users: 1
  • Guests: 404
  • Total: 405
  • Wittsend
attempted air conditioning in a turbo pinto
Started by dholvrsn, August 17, 2009, 12:05:00 PM
I let it the wagon year thing with the contractor slide. It would have only got the guy peeved in a moment of joy.
BTW, I believe that the compressor is probably a Nippondenso rebranded as a Ford. If it is, do any of you AC wonks know of any Nippondenso compressors with the mounting ears, a six groove serpentine pulley, and is R134a ready? With reference number or donor vehicle? Thanks!
BTW, still no UPS dude with condenser. Their tracker hasn't updated since last night.
I am interested in how this all works out as I have an arizona car that has a/c from the firewall back.  I am missing everything forward of the firewall.
Did you remind that contractor that there was no '71 Pinto wagon? lol. I hope your a/c turbo project is a success! How (pardon the pun) cool is that?!
Still waiting for the UPS man with his brown shorts and my aluminumy condenser. Their office says that their guy is on the route. His surname just seems to be Mister Godot.
During this lull, I did try a sliding bracket and compressor with ear tabs from my parts pile. It fits in the space. Now to find a R-134a variant on that compressor with a six groove serpentine pulley.
I read over at TurboFord that the HR980 will run for a year or so filled with R-134a and then will disassemble itself out through the front.  :o
Scratching my head over what to do about the compressor while this project is in a lull waiting on UPS to deliver the condenser. Hopefully I will have some sort of epiphany about what to do about the compressor by the time I get the condenser mounted.
RIght now I'm toying with cutting down the mount for the tangental mount compressor or making a custom one out of ~3/8 plate iron.
I'm reminded about the ordeals that my Dad (Iowa pig farmer) and Grandpa (the Allis Chalmers dealer in Moorhead, Iowa) had with aftermarket air-conditioning in the aftermarket tractor cabs of the '60s and '70s. Pretty kludgy, clunky hang-on stuff that could be temperamental and high maintenance. I wonder how much Dad spent trying to keep cool in the ol' One-Ninety XT over those years, especially adjusted for inflation!
OTOH, AC in the AC!  :afro:
R134a won't hurt it. Just make sure you drain all of the old oil and refill with PAG. The HR980 was a decent compressor. I never use R12 anymore, I convert everything.
Is there a bolt-on replacement for the HR980 that can stand R-134a?
And what does happen if you do put R-134a in a HR980?
lugnut
FYI, your new compressor is a Tecumseh HR980.  Same as what came in my 1987 Turbo coupe. The prevailing opinion seems to be that it should be used with R-12, and not converted to r134a. I would not let that stop me from using it- there is still lots of R12 out there- check ebay.  I also recently saw brand new HR980 compressors in the Ford box for $130-150.
mike
The UPS tracker says that my condenser has arrived in my town, but it hasn't made it to my house yet.
Anyway, two contractors were digging up the street in front of my house and one asked if my Pinto was '71. He bragged about how much he loved his '71 wagon with wood decals back in the day.
Cleaned up my compressor bracket and installed it. Also relocated the horn yet again. The first time was to make way for the VAM. Now moved again to make way for the compressor pulleys... I love "rivnuts"!
Cleaned up and painted the compressor. Probably too much work for something that is half likely to get exchanged.
Also spliced in a compressor pigtail on a Merkur meets Pinto meets homemade harness. I like to solder and shrink tube all of this stuff.
For peer review, here is my schematic for the wiring on this. I'm glad that I got most of this done during the initial engine swap. No wonder that swap dragged on.
Turns out that the pump and bracket didn't have enough room to fit in the Pinto. Now there was two and a half hours in 95? heat and $50 at U-Pull-It well spent....  >:( However these may work on turbo Pintos with the VAM box mounted on the other side of the fender well.
OTOH. with mixed luck, a weird old T-Bird compressor and bracket that I did have already have laying around did fit despite looking too weird and big. :P Now to clean those up for final mounting.
Update/omake: The old compressor set-up that originally came from the factory.
The factory condenser that came out of this car. I dinged it with a die-grinder and took it to a radiator shop to fix the ding. The ding was about the only thing that didn't leak. A more efficient replacement condenser and drier combo is UPSing its way across the US from Nostalgia Air. I was reading about how cars with driers don't have accumulators and that cars with accumulators don't have driers, but this has both. Don't ask me why....
The original factory AC fan and shroud that came out. The fan interfered with the serpentine belts which is partially why I put the electric fan in.
The two electric fans slated for the condenser.
If all those electric fans can't keep up with the heat from the AC and turbo, here's a $5 swap-meet goodie that I picked up yesterday and I may swap in with the factory shroud if it all fits.
The electric fan that I am running now, which is the biggest that I could find to fit the factory AC radiator.
The spot where the old piston pump was and where replacement pump is going.
The replacement pump and bracket from a circa '93 2.3 Mustang at the south Omaha U-Pull-It. I will try to install at least the bracket after dinner today.
The original hoses that will either be reused, spliced, or replaced depending.... Note accumulator on the one hose. I'm a newbie at this, so anybody who knows AC hoses please give some advice.
Ladies and Gentleman! Step this way to see this amazing, most logic defying feat! A man will attempt to install air conditioning into the rare and uncommon turbo Pinto! An exhibition rarely attempted in the civilized world! Not for those of the weak constitution!
My turbo setup in a '79 wagon. I could almost say typical turbo Pinto setup, but even though it's been done enough to almost be a cliche, I don't think that any of them are really typical.
The factory in-dash AC that I will be trying to hook the newer stuff to.
The AC manifold with aluminum heat shield. Also the oxygen sensor on the turbo elbow has been relocated.
The two fan relays mounted on the driver's fender well. The rear is for the radiator fan and the front is for the condenser fans.
