Date: 06/19/2018 03:58 pm
Seeking parts
Date: 10/18/2020 10:35 am
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 05/03/2024 05:37 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
  • Online today: 1,292
  • Guests: 500
  • Total: 500
T5 help please.
Started by smallfryefarm, August 14, 2009, 08:44:27 AM
Saw your other post first so I see ya fixed it. I knew you could do it, all zillion parts fell right into place now didn't they?  :lol:
Well i pulled the trans out and took it apart. the 5th gear fork looks good it may be tweeked ever so slightly back, do you think this would do it? with the top off the case i can grab the shift arm on the side of the trans and shift 5th gear all the way in.
Also inside the case the large gear in the back down on the small part were the syncro is the gear is chewed up like the slider has really had some trouble getting on it but the syncros have been replaced. Is this large gear in back 1st gear, If so i shouldnt have to replace it since i have no issue going into 1st. I have had some problems missing 3rd and was hoping to see this on third, may just be green horning it.
Thanks so much for the input. i am thinking your rite, bent or worn fork on even the tabs worn or missing. I pulled it out of the car put it on the bench put a different shifter on it. i shifted it into fifth before taking apart and noticed that if i turned the tail shaft it fell in gear. Noing i could get parts today anyway i put it back in the car and run it thru the gears and sure enough as long as the rear tires were turning it fell rite in. but not turning it wont go. I am thinking the fork is bent and wont push it enough to engage unless the tires are spinning so it falls the rest of the way on its own. THANKS again for sharing your thoughts!!!!
turbo74pinto
Quote from: 71pintoracer on August 14, 2009, 03:53:48 PM
5th/rev shift fork is worn or bent, not letting it go all the way into 5th. if it was the syncro or blocker it would grind going in. some of those trannies had cheapo alum forks that wore easily
does 5th have the plastic tabs on the fork like the other forks have?  if so, maybe they are broken or not installed.
if i remember right, everything is in the tail shaft for 5th.  shouldnt be too bad to get appart in the car.
bob
ok pinturbo75 i have looked at some exploded views of the trans and see the blocking ring.
Lets look at this like the trans has just been rebuilt. I can tell that it has just been sealed up.
What could they have done wrong to cause this problem. I would hope that the syncros and blocking plates would have been inspected but who knows. Maybe the didnt get one back in by mistake.
but when the car is sitting still and the clutch engaged i push into 5th no sound so i know the clutch is doing its job but as i let out alittle i feel it start to grind. and cant push it into gear.
Quote from: Pinturbo75 on August 14, 2009, 01:45:08 PM
it could also be a bad blocking ring..
thanks for both replys guys what is a blocking ring?
i have tried to even shift it with the shifter off.
i was thinking that the 5th gear fork might be bent.
just drawing at straws
not sure but that sounds like the syncro is off. If it shifts fine through 4 out of five gears its not a "throw" Issue. you could also check to make sure that your not hitting the hole that the lever comes through. (im sure its fine but Id look anyways) if its no the hole, then id think about a bad syncro or a mis adjustment at the clutch
I was running my car thru the gears on the stands. It goes into the gears good except for 5th. When i shift to 5th and let the clutch out it grinds like it doesnt have enough throw. Is their any adustments on the forks inside or do i have a problem. It is supose to be a new rebuild. Any help would be apreciated as i am going to be shooting in the dark when i pull the top off.
