  • Online today: 1,293
  • Guests: 1223
  • Total: 1223
Where can I find a shock bolt for front shocks?
Started by ADaughen, August 11, 2009, 03:40:30 PM
ADaughen
Yeah, I just cut it out and punched out the pieces rusted into the lower control arm.
If I can source some inexpensive wheels or wheel spacers she'll be aback on two of her fours soon.
Still waiting to get some money for the 8.8 rear to be finished up.
'78 Cruisin' Wagon
71hotrodpinto
Hay no problem!
Glad it worked out! Did you ever get the old shock off?
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
ADaughen
Measurements were dead on.
Thanks!
$1.60 side wasn't terrible for nut and bolt, too.
'78 Cruisin' Wagon
ADaughen
Wonderful company called Grainger has any bolt I need.   :lol:
I now have 8 extras on order b/c the smallest box they come in is 10.
'78 Cruisin' Wagon
ADaughen
Quote from: 75bobcatv6 on August 14, 2009, 01:07:11 AM
looks to be a nice little car. I like the 16" mustang Rims your rollin on there those from the 05-09's?
'05s with 8k miles on them.  I need to get new rubber that fits the car.  My old TurboCoupe wheels rubbed up front.
'78 Cruisin' Wagon
ADaughen
Quote from: 71hotrodpinto on August 13, 2009, 09:40:55 PM
well as a last resort see that your cleaning up and freshening up, just sawzall the shock and bolt off on either side of the shock eye. That should free things up. Just need some new shocks as well. Check ebay for deals all the time for shocks.
Uno come to think about it i had to replace my bolts once about 19 years ago. I hit some major pot holes.. or maybe i was 4wheeling,, cant remember but i bent the lower bolts. I went to the junk yard to get mine back then. But that was when there were 40 pintos to choose from. Not anymore!!
New shocks are in stock at AutoZone for ~$18.00 each.
The original photo in '99
Recently
I got rid of the pinstripe and door guards hence the white rustoleum to protect the metal.
IIRC, that hood was one of Pintony's when he came through.  I have a rear wagon hatch from him too.  I still need to smooth out the hood.  It had some really faded stripes on it.
Sadly the wheels don't fit the 11" Granada rotors.  The center hub is too small on the wheel, and the dust cap doesn't allow the center cap.  So I'm probably going to end up with a different wheel or $$ Wilwood brakes.
'78 Cruisin' Wagon
71hotrodpinto
Edelbrock Airgap
Mil
get us some pics of what your workin with and what the car looks like =)
ADaughen
Quote from: 72pair on August 13, 2009, 04:56:28 PM
When reinstalling those suspension bolts or any bolts exposed to heat or the weather, neverseize is a wonderful thing.
Oh, I agree completely.  I have owned the car since '99 and I'm pretty sure the shocks have been on there since '95.
I parked her in '00 due to college.  I finally got married, a house and got the car parked inside 3 years ago and NOW I have time to work on it again.  I'm really motivated to have her running under her own power for 2011 All Ford Nats.
I tried the heat thing, but I didn't shock it with water.  The threads are mauled on the one.  I haven't tried beating on the other.  I just left it alone.
'78 Cruisin' Wagon
72pair
Pinto1600
A thought here, try heating the bolt area to red hot and then hit it with water to "shock" the rusted bolt. A large drift pin and a hammer to push the bolt out. Good luck I've been there myself!
Happiness is..Driving a classic Pinto
ADaughen
Thanks HotRod.  I have a Grainger in town, I guess they are a bolt company, so I'll see what I can find.
I definitely don't want a Grade 5, but I wasn't sure if it needed to be a harder bolt than a Grade 8.
'78 Cruisin' Wagon
71hotrodpinto
AH HAA!!
Ive just done alot of reserch on the bolts that my 71 uses. Ive never measured the 74 and up bolts but because the shock is the same part# for all year pintos, id say that your safe with at least the shock bolt being the same.
Ready for it?
The lower shock bolt is 7/16 14 x 4.5 long. Id use a grade 8 for cheapest way out. HOWEVER if your looking for some permanant shine there is a place called www.Totalystainless.com They have them in polished stainless at stronger than grade 8 strength (150,000 psi) near 200,000 psi tensile strength. They are around $8 a piece without shipping. Theyd never rust in place again!
You dont want to skimp on strenght here. The shock and shock bolt are the only thing that supports the whole car in the event of a bottom out and it hits the bumpstop. If you use a grade 5 ( plain jane bolt) it will bend over time and then youll have to cut it out again. It might even break!
Good luck
Edelbrock Airgap
Mil
ADaughen
Quote from: popbumper on August 12, 2009, 08:27:35 PM
Sorry, recently rebuilt my front end and replaced those bolts, but failed to write down what they were. Best wishes.
So they are readily out there?  Or did you need to find a bolt somewhere?
'78 Cruisin' Wagon
Before you cut it off, measure the length of the bolt.  Then when you get it out or what is left you can take it to a bolt store and find what you need to replace it.
well that sucks. sorry to hear that. i can look at mine tommorow and give you an idea if thats ok? or over the weekend. lol Never know whats going on over here in my house from day to day.
ADaughen
I can't get the bolt out of the control arm/shock.  I'm going to have to cut both ends off from the inside of the control arm and punch the head and threads out.
'78 Cruisin' Wagon
If you can cut it off above the bolt(if you are replacing the shock anyway) then take it to a Hardware store. they usually can help you locate another bolt that will fit the application. Copper state nut and bolt company are really good. i dont know where are you and if there is one where you live but they have been good to me in the past and pretty cheap too
ADaughen
So my shocks haven't been touched in 15+ years.  I went to clean up the front suspension and tried to get the lower shock bolt off and it is rusted SOLID.  I'll have to cut it off.  I've hammered on it enough that the threads are mangled.
Local parts store says "Dealer only or junkyard".  I highly doubt that the junkyard will have a better bolt.  :|
Dealership says the part # is 384375S.  "'No longer stocked."
Ideas?  Anyone have the size and grade of the bolt?  I can go pick two up at the bolt shop if needed.
Thanks,
Adam
'78 Cruisin' Wagon
