76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 05/21/2019 11:50 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 02/18/2017 04:41 pm
Date: 04/07/2021 06:12 pm
Date: 03/15/2023 02:16 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
  • Online today: 125
  • Guests: 116
  • Total: 116
what type of head is on my pinto????
Started by flyboy1, August 06, 2009, 12:56:37 PM
Quote from: flyboy1 on August 06, 2009, 12:56:37 PM
will a roller cam out of a new ford ranger work in the d-shaped ported head????
Yes. And good info on the heads Pinturbo75.
that should be an oval port head with a d-shaped combustion chamber. although if you used a later d-port n/a head with the heart shaped combustion chamber it would slightly up  the compression and give you a little more bottom end torque. the later heads were drilled for both bolt patterns on the intake side of the headand the early ones werent. the difference in the pattern is on intake port 1, the top left intake mount point on the head will have 2 drilled and tapped holes on the later head. your origonal head should only have one drilled and tapped hole there.
flyboy1
i have a 1980 ford pinto runabout with the stock 2.3l. and im buying a new head for it. i called advanced auto parts and they had a lot of different heads...which one do i need to get?
