78-80 Windshield
Date: 10/29/2021 03:11 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Pinto drive train
Date: 06/29/2018 08:32 am
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 06/18/2018 03:47 pm
Date: 08/13/2018 02:46 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
  • Online today: 449
  • Guests: 278
  • Total: 278
door weatherstripping
Started by fordstuff, June 23, 2009, 04:52:08 PM
osiyo59
Rear hatch gasket can be replaced using aa Ford Ranger Door seal from about a 2001 year model. Get the one for the Four Door ranger then you can trim to fit. They are available from JC whitney. Used one on my 72 and 73. Was spot on.
fordstuff
yes door panel off. loosen 2 nuts and wind the window down another inch then change them...... mine didnt have any staples and the replacements didnt either. just the  stocklookign spring clips.... roy
Quote from: 78txpony on July 08, 2009, 01:56:17 PM
Hmmm... I thought mine were stapled, but I need to look again.
I assume you still need to pull the door panel and drop the glass down, right?
They do have staples but they are held to the car with clips built into the sweeps
78txpony
Quote from: fordstuff on July 08, 2009, 01:19:02 PM
sweeps are easy to do.. they have the same clips as stock ones..
-Rob Young
1997 H-D Sportster
fordstuff
sweeps are easy to do.. they have the same clips as stock ones.. i used a putty knife and a small screwdriver to trip the clips and pop them off then the newones just snap back on... as a tip.. remove the inside one first. then the outer ...and install the inner one first then the outer.. its lots easier... make sure the inside edge on the window opening where the holes the clip goes in is nice and straight before you put the wipes back on .. they can pull out a little when you try pry the old wipes off...it makes it easier to get the clips to snap in tight... roy
Quote from: 78txpony on July 08, 2009, 12:13:41 PM
Sounds like the same guy at topsdown...  Right now they are running free shipping if you buy over $100.
How did the sweepers install?  I thought they were stapled but cannot remember.  I need to do these if not too difficult.
78txpony
Quote from: fordstuff on July 06, 2009, 02:44:14 PM
ok.. i got my weather stripping and the window sweeps/dew wipers installed and they are great... i got my stuff from convertible-specialists on ebay..
-Rob Young
1997 H-D Sportster
Thanks for the feedback, that is helpful information!
fordstuff
ok.. i got my weather stripping and the window sweeps/dew wipers installed and they are great.. fit very well.. you have to cut tiny holes in the door weather stripping for theh tiny nylon clips that hold it to theh door but it was easy... i got my stuff from convertible-specialists on ebay.. 100.00 a pair for the weatherstrips and 80.00 for the set of 4 dew wipers. and shipping was 10.00 for all of it ..and i had it in just a few days... I'm very happy. now just for that tailgate stripping.. thanks. roy
Quote from: 78txpony on June 26, 2009, 07:34:45 AM
Yes, Tops Down sells the sweeps, too.
Let us know what you think of them.
I did not get them, but now wish I did...  Next time!
78txpony
Quote from: fordstuff on June 25, 2009, 05:12:40 PM
also got a sert of window dew wipes from same place. for no extra shipping chg.. yea
-Rob Young
1997 H-D Sportster
fordstuff
fordstuff
thanks. i ordered door seals.. now just to find a tailgate one.. roy
Door seals are the same.  I have put sedan / hatchback seals on my wagons with no problems.  The tailgate seal is different between the wagon and sedan / hatchback.
78txpony
Not sure about the tailgate w-strip, but see this post about the door weatherstrip, particularly post #3...
http://www.fordpinto.com/index.php?PHPSESSID=0224981a73f2139f6a771220b8c5677f&topic=8658.0
-Rob Young
1997 H-D Sportster
fordstuff
i need door seals for my 74 wagon.. are they the same as coupe or hatch?. and how about a rear tailgate gasket?.. thanks. roy in columbia
