1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 09/26/2019 05:31 pm
Date: 02/03/2018 11:28 am
Date: 04/07/2021 06:12 pm
Date: 05/24/2020 08:19 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 04/04/2020 09:38 am
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Wagon rear quarters
Date: 06/17/2020 03:32 pm
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 190
  • Total: 190
Joe's 1974 Pinto Wagon
Started by redmustangman3, June 17, 2009, 11:03:31 AM
Looks great!  I think the 'shiney police' would be happy. :police:
Hmm... I had the same problem with my 78.  Turns out the cowl is galvanized.  My 76 M2 is the same.  I think they did it to try and help with the rust-thru these cars all seem to have in the cowl area.  The paint that I had was factory original, but after 20 odd years of Arizona sun (it started cracking/peeling in the late 90s), it was looking pretty sad.
redmustangman3
I don't know what happened to the new photo but here it is I hope. Joe
1971- 289 V8; B&M C4; 9" with 4:11 posi. Several suspension upgrades and body modifications.
1974- 2.3L wagon,4-spd,totally stock. Medium lime yellow, avacado interior, 99k miles.
1972- 1984 Mustang SVO turbo; 5-speed tremec; 9" rear w/positraction; fiberglass front & doors; upgraded suspension.
redmustangman3
Update time- the paint on the cowl area needed to be redone. I don't know how or what was used to repaint it, but the paint was literally falling off? At least there was not much rust. So off to my local paint shop; they loved the car and the unusaual color. They said it would take 3 days and they would be using a water base paint which a lot of shops use nowadays because of CA/ EPA regulations on laquers, etc. 4 days later I called and found out they couldn't match the color using these water base paints. They would use lacquer which would take 2 days to order- no problem I'm in no hurry. 3 days later I call again and the color was a great match but they company had put pearl in it. Time to reorder the paint again- another 2 days. Long story short, it got painted and it looks really nice. Joe in Morgan Hill, CA
redmustangman3
Quote from: lugnut on August 28, 2009, 11:43:05 AM
Hi Joe,
If you want to see what an a/c Radiator looks like, stop by my place- my cruising wagon has factory ac.  I also may have a turn signal lever for you.
mike in morgan hill
Hi Mike: I'll take you up on that. I would like to show you my newly aquired 74 wagon anyway and take a look at the signal lever. Regards, Joe
lugnut
Hi Joe,
mike in morgan hill
Quote from: redmustangman3 on August 13, 2009, 09:47:33 AM
I'm not sure what an A/C radiator looks like but the new one is significantly wider than the original. The original one was 18.5" wide and the new one is +22" wide. It also has fittings on the bottom which have been blocked off (auto trans?). Hopefully bigger is better and it is definately shiny-Brad will like that. Joe in Morgan Hill, CA
redmustangman3
Thanks for the tip on the door knobs; I'll check into vintage mustang ones. Joe
Quote from: redmustangman3 on August 22, 2009, 10:44:31 AMAlso looking for door lock knobs (X2). The ones on the car are broken and the ones at auto parts stores don't look all that hot. I'd prefer NOS stuff but pieces in very good shape will also work.
If they look like these, the ones for Mustangs should work.  I can't remember at the moment, but the Fox body Mustang ones MAY be a bit longer, but still should work as the threaded rod for them has remained the same diameter and thread count since at least the 60s.  If you don't like the look of the smooth ones without heads, you could use early Mustang ones instead, like from a 67 or 68.  My 69 F-100 uses the ones like are on 68 Mustangs, but I switched them out for Pinto knobs and stainless grommets for a cleaner look.
http://www.superiormustangparts.com/proddetail.asp?prod=5R3Z-6321850-S
I should have a turn signal lever for you.  I will check and get back to you.  I will look for some door locks but I am not sure if I have any.
redmustangman3
 Hi Group: Looking for some small pieces for the 74 wagon. The end chrome (or plastic) piece is missing from the turn signal lever on the steering column. It looks to be a push fit; or will take a new complete lever. Also looking for door lock knobs (X2). The ones on the car are broken and the ones at auto parts stores don't look all that hot. I'd prefer NOS stuff but pieces in very good shape will also work. Please contact me off list at gwnv63@prodigy.net. Thanks, Joe In Morgan Hill, CA
redmustangman3
That looks like an AC radiator.
redmustangman3
Update time- finding a radiator. The short version is the new radiator, hoses and misc. pieces have been installed and I'm finally driving my wagon again. The long version is Kragon autoparts store cancelled 2 seperate orders I placed for a Pinto radiator which they stated was available at their warehouse. After the second order didn't show up (some + 2 weeks later) I located the store owner and had a discussion. The botttom line is Kragon's inventory computer system sucks, and their source for Pinto radiators (in Mexico) no longer makes the part. He found a new one (at twice the cost) and I had it in 3 days after our little discussion. I've included a couple of photos. Joe in Morgan Hill, CA
Just remember Joe... if/when you get tired of that ol' wagon you can drop it off here at my house... ::) :hypno: ;D
redmustangman3
Thanks Paul, I didn't think about that given the 100 degree temps we have had recently. I'll check it out. Joe
skunky56
Joe, don't forget the heater core when replacing the rest of the system :0)
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
Nice looking wagon!!
I hear ya about Ca. That's the only state that assumes you are driving the car even if it isn't registered, so they make you pay back registration.. Morons.. I just re-registered my car for the first time since 12-06 and since there is only 6 months till my birthday (registration expiration) I only had to pay a prorated amount.. No fees and no questions asked, except it I have been driving it or not.
That is a great deal for that wagon though. Wish I had the cash for something like that.
Very good catch!!!!!!!!!!!
Scott Hamilton
Joe, that IS a really nice wagon!
Looks like you really found a special gem... Really really neat find...  She is in great shape, the engine, the interior-- a real find...
Nice,
redmustangman3
Just a quick update on getting the wagon in great driving shape. I took it to my local mechanic who maintains my Pintos and had all the filters and fluids changed. It had been sitting for +two years so taking no chances everything was changed. He fixed the window regulator (replaced rollers), fixed the directional signals (fuse) which also made the electric antenna and radio work, fixed the choke and did a safety check. I was nervous about the brakes but he reported they were in great shape as was the rest of the car. I had previousy replaced the two rear tires as they had deep cracks in the sidewalls. The fronts look good. When I picked up the car, I decided to take a little drive around town which was super fun. Then home and parked it in the garage. About two hours later, my wife came in and said you better check your new Pinto-something is leaking. How about a quart of Prestone on the ground- yikes!! Long story short; I have a new radiator , hoses, and thermostat on order. Should be in next week- special order from Kragens. I'm not upset, the car is 35 years young and has been sitting for awhile so you can expect some issues. I'll let you know how it goes. Joe in Morgan Hill, CA
redmustangman3
Hi Leonard: Absolutely; although driving the Shelby Mustang is a kick ?? Joe
lencost
Hay Joe! Can we expect a wagon next time?
1975 Wagon 8" C4 2.8 V6
Joe, I think you got a great deal, that is a wonderful looking car inside and out!  :)
Pangra74
Joe,
This is Joe in Oakland. What a nice find. I have an 06 Focus wagon I use for a daily driver and have thought many times that if I found a clean wagon like what you have there, I'd dump the Focus (although it is a really good car) and use the Pinto wagon as a driver.I'd keep my runabout for the other stuff.
Congrats!!
Joe in Oakland
1974 Orange Runabout
redmustangman3
Hi: Just back in town from Nascar Race at Infineon Raceway this past wekend- what a blast. To answer your question 71 Pintoracer; the previous dealer/owner had it listed on eBay with a $3500 reserve; it didn't sell. I contacted him several days later and made an offer of $2500 which he accepted. There were other fees involved, including 2 years of DMV fees and fines- only in CA!!! Once I saw the car in person and gave it a car wash and a short drive around town, I was more than happy with the deal. It's not perfect; directionals not working, passenger window regulator not working, the front cowl needs to be repainted, etc. As for the color; I really liked the pictures as posted on eBay, I thought it was yellow. When I saw it in person, it was greenish yellow. It's really strange- in direct sunlight, it looks yellow. In shade, it looks green. In normal daylight it looks greenish yellow. It's starting to grow on me as it is so different. In any case, it will stay that color for quite a while. I need to get the mechanical issues in order. Regards and happy with my new 74 wagon- Joe in Morgan Hill, CA
Beautiful! I think that's definitely daily driver quality! Wow and I love some of the unique 70's colors including that of you wagon. Have fun with it! Congrats
Yeah... Chrisf will have to keep a beady eye on me...!  ;) That wagon is SWEET!
WOW!!! :o What a beautiful Pinto! :amazed: Do you mind if I ask what it you had to give for it? Not trying to be nosey :P just wondering what a pristine car like that is bringing!
Did anyone see the one on Barrett-Jackson last year? What did it go for? 11 grand? is that right? ???
chrisf1219
hey joe its going to cost extra if i have to guard your air cleaner on the black car and parts off the wagon. just kidding   chris
What a find :amazed:     CONGRATULATIONS!!!
pintoman
Looks just like the one at Carlisle this year.One of the venders had it,wanted $5500.It sold on Sunday.
