13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 03/25/2019 09:02 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
  • Online today: 642
  • Guests: 172
  • Total: 172
2300 idles rough
Started by fordstuff, June 08, 2009, 09:12:16 PM
Just a thought, but you might also want to remove the valve cover and check out the camshaft if you have not already done so. Many of us have had problems like you described and it ended up being a worn cam lobe. If that is the case I would suggest to going with a roller cam and rockers to help prevent the problem. They can be found on mid to late 80's 2.3 engines going up to about 1992.
Roy for accuracy best way turn crank until cylinder you are checking is on compression go top dead center pump  air into cylinder go back listen to ex pipe for air leaking past ex valve, then air filter off listen for air leak at carb, intake valve leak, now pull oil fill cap off listen for air leak this is to check rings.  Fred   :)
fordstuff
thanks fred i'll check. woudla compression test show the valves?. it runs great on the highway... roy
Quote from: Fred Morgan on June 08, 2009, 10:09:12 PM
Roy when you turn idle mix screw all the way in engine should stop running. Sounds like you have air leak but could be valves. While engine running spray all intake connections with WD-40 if idle speeds up then there is youre air leak.  Fred   :)
fordstuff
it ran rough when i got it so i got the carb and put it on.. and still idles rough. but its a champ on the road.. cruises down the freeway at 70mph and over 30mpg easly..... thanks. roy
Quote from: phils toys on June 08, 2009, 10:11:08 PM
Did you have this problem befor you rebuilt the carb?  how many mile on the engine?
mine is somewhat the same  untill it gets realy warm (like a 30  mile drive)   then it usualy is ok.  i have not rebuilt my carb.  76 /90,000 or so miles
fordstuff
ok my 2300 in my wagon. auto trans. put a rebuilt carb on it and changed ign. to 77 electronic. runs great on freeway.. but when i slow to idle it stumbles and shakes and feels like it could stall at any sec. i don't feel any vac leaks.. ive wound the air fuel screw in and out a bit and no change. moved timing a little.. i can get it to idle up a little but usually slows back down and sounds like death warmed over and gaspign for air before death.. ideas on what might be up with it??..... thanks roy in SC
