Date: 10/26/2020 03:24 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 11/29/2018 10:26 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 09/20/2018 11:01 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
  • Online today: 500
  • Guests: 379
  • Total: 379
Coil spring differences
Started by r4pinto, May 16, 2009, 09:18:30 PM
On my 75 the A/C was removed before i got it and it is very nose high.  I too am getting new springs....
Quote from: Carolina Boy on May 16, 2009, 11:56:39 PM
I was right, I was right, the medicine is working!!!!!!!!!!!!
share the wealth.. I could use some good medicine.  Mine stopped working a long time ago lol
I see said the blind man... I don't want that & unless I get a/c before the coil springs I will spend the extra $15 and get the right ones.
Carolina Boy is right. It's spring rates. If you want stock ride height, go with the springs rated for how your car is equipped or you might end up nose up... :hypno:
Hmmmmm... I might go the "cheaper route" and get the ones for the a/c sedan then. The part number for that set is actually the same for a non a/c wagon.. One of the reasons I was confused. Trying to get all the parts together before I try to do a front end rebuild. I really should write up a parts list for that.
Seems to me it would be the spring rate, as wagons are heavier and you had the 4 cylinder and heavier V6. :read:
I am pricing new coil springs for my car and I noticed there are different ones listed depending on weather it is awagon or not, or if it has a/c.
What is the difference? I have a 77 sedan with no a/c but saw the springs for a 77 sedan with a/c is about 15 dollars less.
Any info?
