Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 06/18/2018 03:47 pm
Date: 06/22/2017 07:19 am
Date: 02/21/2017 06:29 am
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 04/28/2018 04:12 pm
Date: 03/23/2018 09:23 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
  • Online today: 1,293
  • Users: 1
  • Guests: 173
  • Total: 174
  • Wittsend
I'm tired of chasing a little oil leak
Started by slowride, May 15, 2009, 01:30:13 PM
slowride
Had some daylight and a few minutes while I was checking for leaks, so here's the end result. I wanted a kind of stock look, so I stripped the paint and went with the "as cast" finish. And yes, it's dry as a bone now  ;D
slowride
I installed the turbo valve cover with the silicone Felpro gasket this afternoon. I am NEVER messing with a cork 2.3 gasket again! Went on easily and sealed great... couldn't ask for anything more. This should be it for leaks. Now I can start cleaning and detailing the engine.
slowride
I ordered the Felpro molded gasket to use with the turbo cover. If it doesn't do the job, the Ranger gasket will be next.
x2 on the ranger gasket. and its usually reusable.
Mike Modified
A lot of the turbo guys recommend the late Ranger ('95 up?) gasket, http://forum.merkurclub.com/forum/viewtopic.php?t=10462&start=15, with the cast cover.
On my dirt track car I used the aluminum V/C with a rubber/silicone type gasket and it never leaked. Never put sealer on one of those type gaskets. If you put indian head on both sides of a cork gasket you'll never have any leaks, but you'll never get the v/c off again!! That stuff seals anything!  :D
That's a factory piece for a later turbo with the shorter upper intake manifold.
slowride
This is what's going on it.
slowride
Quote from: dave1987 on May 15, 2009, 04:48:55 PM
I agree with it possibly being the stamped steel cover. Mine is slightly warped around the bolt holes due to my father and cousin over tightening the bolts with a cork gasket. I have the molded silicone gasket on it now and haven't had any leaks. Would like to put one of the thicker aluminum covers on it, but I want to keep the originality.
I can understand the originality deal.Though mine is relatively low miles, it's far from original, so no reason for me to be a purist. The cover I bought doesn't have the normal "Turbo" or "injection" on it..... heck I doubt it's even a factory piece. I just hate leaks is all........
slowride
Quote from: dick1172762 on May 15, 2009, 02:55:13 PM
Never seen a rubber gasket that didn't leak. Use a cork gasket.
I already have one of those that does. I'm thinking the majority of the problem is the stamped steel cover. The rail on the aluminum cover is thick and will take an act of God to distort.
There is this stuff called "Indian Head Gasket Shellac" It is sold at most parts stores & is mabde by Permatex. Wouldn't hurt to try that if the leak still exists.
slowride
I've been chasing a little stinking oil leak from the left front v/cover bolt and I'm tired of screwing with it. I bought an aluminum turbo cover and have a molded rubber gasket coming. Is there anything else I need to know (or do) to get this thing sealed once and for all?
