Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Date: 08/30/2021 03:20 pm
Date: 03/15/2023 02:16 pm
free transmissions
Date: 11/28/2019 10:21 am
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Windshield
Date: 01/15/2022 09:31 pm
  • Online today: 1,293
  • Guests: 167
  • Total: 167
Question about "pedal hangar"
Started by popbumper, May 15, 2009, 01:27:46 PM
turbowagonman
My current wagon WAS an Auto, I then swapped it to the 5 spd. When I had the Dash out (on both rides) all I did was replace the Pedal assembly with leaving the Meatal Barckets in place. So the Backet off of the firewall is the same they just have nylon spacer in between the pedals and the bracket.
turbowagonman
I'm not referring to the pedals you show in the pics, I am referring to the large "metal bracket structure" that the pedlas hang on.
Tom yep the lower picture. Did you get the engine head finished.  Fred   :)
I have heard there are four different pedal set ups for the Pinto. There are the early cars (71-73 I believe), there are the 74 and up cars.  I was told that the booster cars had different pedals.  Where does the fourth type come in...? I don't know, but I'm sure someone here does.
Hey Fred, was that the pedals (in the picture) I swapped with you at Knott's '08 ?
Tom
The top 1 is 74 the lower is 78. They mount completely different. Fred   :)
My bracket (standard tranny) is out of a '76; I pulled the other auto tranny bracket from a '78 hatch. Was hoping to restore the latter one, so when I pull my dash, I can just pop in the fresh one. Hopefully that will be the case.
The channel is the same 2 and 1/2" across inside diameter. Latter models are 3 and 1/8" wide.  Fred   :)
slowride
I haven't seen them side by side to compare, but I just swapped in an automatic pedal in place of the original brake and clutch pedal. Direct fit. I can't see what functional difference there would be.
...well, that's what I am gonna call it right now....probably is not spelled right, either.....
This is the piece under the dash that the pedals mount to. I pulled this piece out of an Automatic since the dash was out and I had easy access.
QUESTION: Are these pieces DIFFERENT between an automatic and standard transmission car? (yes, I realize there is an extra pedal in the latter, but I am curious if the structure of the hangar is different since one has a brake pedal only, and the other has a brake and clutch pedal).
Thanks!
