Date: 08/13/2021 10:39 am
Date: 06/07/2021 08:14 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
74 hood
Date: 07/03/2017 03:46 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
80 pinto original
Date: 08/04/2019 10:45 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 09/03/2018 08:58 am
  • Total Topics: 16,268
  • Online today: 673
  • Guests: 259
  • Total: 259
ignition problem?
Started by volksnut, May 07, 2009, 07:29:25 PM
could be the ballast between the Ignition coil and the battery. Id start there if you were able to start with a Direct connection from batter to coil then look at the ballast. Should be fairly cheap to replace
volksnut
Got a call today from the daughter, she said her car wouldn't start after leaving work. I stopped by on my way home and sure enough it wouldn't start but would sputter and try to start almost like it was flooded. I finally got it to crank and it sputtered and had what was like something grounding out. I went home got my tools/testers etc. to check it out, I checked to see if it had 12 volts to the coil and found it had 5 volts with the key on????, So I ran a hot wire from the battery to the coil and it fired right up and ran great...I disconnected that wire and it still had 12 volts to the coil but when I shut it off only had 5 volts??? I tried to get it to do the stalling/sputtering deal again and it never did... What would give that low reading...I'm thinking maybe a ignition switch?  Any ideas...I hate intermittent problems
