Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 02/14/2019 06:27 pm
Date: 07/21/2017 11:49 am
Date: 08/06/2021 02:23 pm
Date: 06/18/2018 03:47 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 02/18/2017 04:47 pm
Date: 02/18/2017 05:55 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Online today: 1,293
  • Guests: 1199
  • Total: 1199
D7-6038 motor mount
Started by Carolina Boy, May 03, 2009, 11:13:22 PM
The more I read this post the more confused I get!  :read: ??? Mounts and brackets and 289 frame stuff.... :P
Not that I really need it now, but it would be nice to know in case I V8 the cruiser in the future. There have been bunches of topics on this and it seems like they are all different. So yes, pinto project, if you could take pictures and give part # of what you use and how well it worked, you would be helping a good many members!
pinto project
Quote from: popbumper on June 10, 2009, 09:51:54 PM
OK, so the mount is available at Autozone under the number you listed. Cool. Then, all I have to do is find '66 Mustang 289 brackets, which bolt to the frame. If this is WRONG, say so. otherwsie I think I finally have it down.
no as you can see from the picture carolina posted is both pieces made together(the two holes on top the mount bolt to the motor and the bottom two holes slide over your frame)the only problem is the fit has some slack in it where you bolt the mount to the frame ,but with a couple of washers on each side it should shim up easy enough. but if you had the upper brackets that bolt to your small block mount the 2344 part number fits tighter but its all what you want the 2344 was $1399 and the part number carolina gave you was $9.99 iam going to try and use them. droping in v8 today with transmission starter and headers already bolted up. wish me good luck and ill let you guys know how its going.
i have a 78 pinto radiator and bucket seats and a driveshaft for sale if you need one.
pinto project
Quote from: Carolina Boy on June 10, 2009, 09:42:32 PM
Whoa there boys! The bracket is bolted to the frame.
The mount is bolted to the engine.
You lower the engine with mount attached, down over bracket and put bolt thru hole of the ears of the mount, thru bracket.
Picture is the mount
the 2344 i got from auto zone didnt look like this one what is the part number and price and where did you get it thanks the 2344 needs a bracket the bolts to the moter mount and the bracket bolts to the engine. any help id appreciate it carolina.
71hotrodpinto
Heres how i mounted my setup.
They are early (64?) Early Falcon mounts on some frame mounts that i got on ebay. The mounts were from a defunct company in the 70s.
They could be duped from some 1/8 plate steel, something to cut with and a welder. I can supply some dimensions if you want them.
One of the disadvanteges of these mounts is they can and will rip with big HP or TQ. There is no bolt thru design that will prevent the rubber from over stretching. However they have and can be modified with some work to include a couple of bolts and some nyloc nuts to act as an "engine strap".
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
pinto project
Quote from: Carolina Boy on May 04, 2009, 07:04:42 PM
There is a company called Anchor Industries that makes Motor mounts for autozone and other auto prt store. I just left an email with them about the availablity of A-2344, replacement for Ford's D7ZZ-6038B. I'll let you know if they respond.  :rolleye:
Do you or one of the other guys or girls have one or a close up picture I could use as a reference? Do you think it is the mounting ears that set it apart from other mounts.
ijust did some research on d722-6038b (2344 auto zone part#) two availiable 13.99 each have two order made for a mustang ii 1976 hope this is the right ones jegs told me the number also so did research on web.
THANKS for clearing that up, it was painful for me  :laugh:. Seriously, since I have never looked at this setup, it was hard to visualize!
Use The 2.3 frame brackets. All you need is the mount. I bought a pair of mounts today and they do work.
you can ge tthe brackets from any 289 you find in the junkyard then buy new mounts from autozone for that year vehicle i think, and be good to go.
OK, so the brackets are what CB was talking about - I assume then you would also need mounts (isolators), which should be as easy to find. Thanks!
The mount is the Isolator it bolts to the Engine and then to the frame Via the Bracket. So yes mounts are usually two parts.
CB:
  Can you clear somthing up for me? These are mounts, right? What about BRACKETS? In all of the reading I have done, both "mounts" and "brackets" have been mentioned. Are these the SAME? Or, are there two different parts involved - a bracket that bolts to the frame, and a mount that interfaces the motor block to the bracket?
  Anyone else? I've never changed a motor out, so it's somewhat greek to me. Thanks!
This is the best news I had on this site. Just checked with Anchor Industries and they are available and also at Autozone for $12.88 each. I think I will go get some later this morning.
The part number for Anchor Inc. and Autozone is #2257 :amazed:
All small block ford will work popbumper with that set up
Nice info, thanks!! But these will fit 289 only, yes? Not 302? Sorry if that's a dumb question, I assume they are the same block, 302 has a bigger bore or longer stroke, whatever.
Now that thar is good news, Alot of the guys are going to be happy about this! Thanks and thanks especially from me ;D
nope from what i have see,,they`ll bolt right in
Hey, We may have a winner!!! ;D These are bolt in huh? Any change on the frame bracket, like use two driver's side bracket or such? thanks for the info. Web search time!
1966 ford mustang 289 mounts will bolt right in ,,,small blocks only though
Got a call from Anchor Industries and was informed that the Anchor replacement for D7ZZ-6038, will not be going back into production. There is not a demand great enough for it. >:(
I'm not giving up on my research! I will find something to work for us.
Got an email from Anchor Ind. and they said it was a discontinued universal part that would work on any 302 car from 1964 thru 85. The email had a phone number. I caled and spoke to a guy about the mount. He told me there was no such replacement part for the D7ZZ-6038b and that I had the wrong number. I tried to explain I got the number from their website and was hung up on! :nocool: I cooled off and called back and asked for a supervisior, CLICK, hung up again. :mad: I swear I heard his zits popping. OK now I'm really *&#@ed off. I pulled the site back up and found a VPs name and grabbed my cell phone (different number) and called again. I ask for this VP. I told zit face, "put me thru now and never put me on hold again!!". Ring, hello, may I help you. I explained the problem and he said the part was discontinued due to lack of interest. I told him about us and MustangII club and he will see about getting them back into production, and he will let me know when they are available for purchase. He seem like a pretty nice guy.
Got a wee bit busy driving around....sorry.
They could only find that the 6038 mounts were only every used on the Mustang II from 76 out, no other cars used them. :(
Now don't go out of your way, Take your time. 8)
Tell you what....I'll go down to my local Ford dealership today (they've been wanting to see the Pinto with the valance on anyway), and I will have them look up the part number and have them tell me what other vehicles it was used on. I'll get back to you after 9 AM mountain time (an hour and 20 minutes from now).
Is there any other mount that you can use for the 74-78 V8 swap? Was it used in any other car and thru what year? I really don't want to use solid mounts or engine plates.
