pinto parts for sale
Date: 07/25/2018 04:51 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 11/05/2016 09:03 pm
Date: 08/08/2018 12:26 pm
Date: 03/29/2019 07:20 am
Date: 04/08/2018 05:47 pm
Date: 10/03/2018 10:46 pm
  • Online today: 600
  • Guests: 331
  • Total: 331
Super Pinto
Started by 69GT, April 30, 2009, 11:58:04 PM
thanks for the pictures.  if you have any more, like the belt drive, i would appreciate those too.  And any words of wisdom would be appreciated.
69GT
Here is a link to my early post with some more pics. One is on the bottom of the blower.
http://www.fordpinto.com/index.php/topic,10333.0.html
Quote from: 69GT on June 09, 2009, 03:52:54 PM
It's an Eaton M90 off a T-Bird SC. Using a Volvo front mount intercooler.
I am very interested in your mount for the m90.  I am looking at a Gm style with bottom discharge.  Any advice or pictures would be greatly appreciated.
its from a 1995 t-bird SC. I have the ECU/ Wire harness and the Motor. Going to put an AoD behind it. makes i think 6lbs at max, I want to get atleast 12, I am rebuilding it with better internals, My goal is to push about 350-375 hp at the rear.
Mike Modified
Looking really good.  Got any pictures of the blower mount?
69GT
   There is a place that will rebuild the blower "better". Cant remember the name. They rework the inlet and outlet and coat the rotors. What motor do you have? The reason this blower isn't making more boost is because we are having a hard time finding the right pulleys to speed up the blower. The blower we have (Stock) should be plenty good for 15-20 PSI efficiently on a 2.3 if we get it spinning fast enough.
same one i am going to be using on mine. here is my question, is the m90 able to be Changed at all? Internals I mean. If so can someone point me in the right direction, Have the motor now sitting at my bosses in their garage. Need to know what i can change internally to make more Boost. im aiming for atleast 12-15psi not 5-8.
69GT
What kind of blower is that?
I'm guessing Buick Riviera, but I'm probably wrong.
69GT
  Just an update. Super pinto has been fitted with the biggest lower pulley (Smallish crank pulley off a Ranger) and the smallest upper pulle for the blower and is seeing 10-11 LBS of boost. It fries the tires pretty good and instantly goes to full boost. Looking for ways to drive the blower faster for more boost. A jack pulley might be in the future.
69GT
One more...
69GT
And I'm having computer picture posting problems.... STILL!! The friggin thing will not re size the pics and even though I told it to post three different pics it just copied the first one 3 times...
69GT
That's an SVO scoop off a junkyard SVO.
69GT
 A hood experiment..
