  • Online today: 1,972
  • Guests: 997
  • Total: 997
Compatability of body panels - Pinto to Bobcat
Started by FlyerPinto, April 29, 2009, 03:22:39 PM
FlyerPinto
Thanks for the info folks. Every time I've tried a search I seem to end up with a mess, so I just asked the question. Sorry.
1977 Bobcat HB
1977 Bobcat HB
1978 Pinto Cruising Wagon
the floor pans require a bit of work, other then that everything other then hood/Grille are about the same.
The MII floorpan incompatibility with the Pinto has been discussed here many times before. Do a search to find out more.
DBSS1234
Rear fender panels are the same, not sure of the Mustang II floors.
FlyerPinto
I have found rear fender sections (new) that are supposed to fit 71-80 Pintos. I want to be certain they will fit my 77 Bobcats. As far as I know the only differences between the cars was pretty much cosmetic, tail lights, hood, grille etc. I just want to be sure before I spend the money on them.
Also I've found reproduction Ford Mustang II floor pans...will they swap over to the Bobcat?
1977 Bobcat HB
1977 Bobcat HB
