WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 08/20/2017 01:34 pm
Date: 01/20/2018 07:51 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 04/13/2017 04:56 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
  • Online today: 179
  • Guests: 158
  • Total: 158
Parking Lamp / Turn signal Malfunctions????
Started by TIGGER, September 28, 2004, 01:43:54 AM
On my 78 I had similar problems, and mine was caused by fried wiring, going all the way back to the steering column connector. I cut out all the bad wiring, and replaced it, and all is good now.
Hope that's not what happened here.
losin sux
77 HB 2.3 C3 3.40
Seems like every Pinto I own has or had issues with the front parking lamps/turns signals.  For years on my 79 wagon, the right front turn signal would cause problems.  I could jiggle the socket and clean the ground and it would be OK for a while.  When ever the turn signal light (dash) would come on when turning on the headlights, I knew I was going to have problems.  Sometimes the parking light wouldn't work but the turn signal would still work on that side.  Other times the turn signal wouldn't work.  It was wierd.  One day I was jiggling the wires and one of the wires came out of the socket.  I pushed it back it and it snapped further than the others.  So I pushed in the others and have not had a problem since.
On my 73, the drivers light does not work at all.  No turn no nothing.  Bulb is good and the ground is clean.  Wires seem to be plugged into the socket properly?  I have not done any more debug work as this car is being stored.
Now on my 78 Cruiser Wagon, the drivers front doesn't work at all.  The socket is different than my other two cars.  The wires look to be sealed in the pulg housing where the others are removeable.  If you jiggle the bulb it will work till you let go.  The pass side was working but was dim.  I played with it and now it doesn't seem to work at all and now the dash turn signal lamp is on again.
I am guessing the sockets are bad but I am not sure.  Any one else have problems with their front parking lamps?
