WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 08/22/2017 09:21 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 07/17/2019 05:23 pm
Date: 10/24/2019 01:43 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 07/21/2017 11:49 am
Date: 10/10/2019 09:42 pm
Date: 10/24/2018 07:41 am
  • Online today: 642
  • Guests: 147
  • Total: 147
1991 2.3 motor?
Started by fastfred, April 21, 2009, 08:48:36 AM
Im about to do the same thing. Found an 89 mustang 2.3 engine for $50 says it has a lifter tick but it comes with computer and wiring. Anyone have any info on how to wire this up or how much fuel pressure it needs? I dont know if this engine is DIS or if its 4 plug or 8. I figure if nothing more the cam and lifters are useful atleast.
You will need to use a 2.3 Pinto oil pan too.
The dual plug head was not the greatest for performance, but they ran OK. The c3 and header will bolt up. If you plan to use the fuel injection (which would be nice) you will need the wiring harness, PCM, fuel pump, relays ect. There will be some mods that will need to be done but it is doable. If you want to stick with a carb, first you need to make sure there is a hole in the block for the distributor. If not, you are looking at having it machined or using an aftermarket crank fire system. There is also the issue of an intake. The 8 plug heads were never carbed so there is no intake that matches the ports. However, Fred Morgan put a carb on one, You can contact him and see what he did to overcome these obstacles.
fastfred
I have the chance of replacing the mid 70's 2.3 Pinto motor in my custom car.
The motor is a 1991 Mustang 2.3 with fuel injection, 8 plugs and dual coils. Only done 50000 miles and for $275 may be a good deal.  ;D
What will be the issues in connecting it too a my C3 trans. and will the headers line up and any mods in having a fuel injection set up. Any thoughts will be helpful.  How much more power will it have? I will need to get a motor hoist etc.
Regards  Fred
