Date: 08/09/2018 07:49 am
Date: 01/24/2021 07:54 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 11/04/2018 02:34 am
Date: 08/09/2018 11:09 am
  • Online today: 1,009
  • Guests: 979
  • Total: 979
STRUT ROD bushings?
Started by popbumper, April 08, 2009, 09:33:40 AM
You guys are great, that's what this group is about. THANKS!!
Chris,
You'll need 2 for each side. Think of one to keep it from pushing thru and one to keep it from pulling thru as the suspension moves up and down changing the arch distance (why you need it to give). I got black poly ones from Energy Suspension (google). I can do pics later if you need 'em, let me know.
71HANTO (Texasite in training)
You can see my bushing behind the rotor on the frame
The strut is the 3/4 inch diameter rod that bolts on to the lower controll arm out beside the lower ball joint, goes back to the frame and goes thru a hole in the frame just under the fire wall area you need a bushing on each side of the hole.
Thanks - but why do you need 4? The lower control arm pivots on the frame at a single bolt, so I'd think you'd need 2....
Still a little confused....
I bought a new set off of ebay. They were red neopreme. ENS-4-7113R Bushings Strut Rod Front Mustang II/Pinto    18.99
I beleive they are the bushings on the strut that goes from the lower controll arm back to the frame.
Hi all:
  Getting ready to order parts for my front end rebuild. There is some confusion on terms - since the various vendors and the Ford parts catalog tends to name things somewhat differently.
  My question is this:
What are STRUT ROD bushings? OK, I understand control arm bushings, sway bar bushings, stabilizer bar (same as sway bar) links/bushings, and rack and pinion bushings, but what are STRUT ROD bushings? Are these for the SHOCKS? I really want to order stuff right the first time....thanks!
