Date: 05/24/2020 08:19 am
Date: 07/11/2023 11:39 pm
Date: 12/09/2018 11:35 pm
Date: 11/11/2019 04:49 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 08/22/2017 09:21 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 04/12/2017 06:57 pm
  • Online today: 1,293
  • Guests: 995
  • Total: 995
2.3 Head Bolts demysified (hopefully)
Started by Wittsend, March 27, 2009, 04:35:06 PM
Mike Modified
There is a LOT of mis-information going on out there regarding 2.3 head bolts.  I spent  some time in gathering this information and thought I would create a separate post to make it easier to find.
My assumption is that with two types of bolts used people often reply according to "their" experience. Others then accept that information and it becomes "gospel."  Hopefully from what I have gathered one can make the right considerations.
Bolt types:
  As best I can tell all the replacement bolts are now 6 point, TTY (Torque to Yield). They are 51 foot pounds of torque,  re-torque to 51 foot pounds - plus a 90 to 100 degrees rotation.
Note:  The Ford instructions say "retighten".  They never say to loosen as some have implied.  Yet one more mystery to uncover! Frankly it doesn't make  much sense to tighten and then loosen a bolt that has one time use - even if it hasn't torqued to the maximum yet. I just did it to 51 foot pounds and then checked them again for the same value.
  But, some of the Ford 2.3's came with 12 point "regular" torque bolts. They are a two-step torque 50-60 foot pounds, then 80-90 foot pounds. In my case my 1988, 2.3 Turbo Coupe came with 12 points.
After searching the TurboFord site this is what I basically found:
1. If you have the 12 point bolts they CAN be reused.  I saw one comment up to three times. They apparently are NOT TTY bolts. It was cautioned that you should ensure their condition.  If your a junk yard kind of guy like myself (cheap) I would pull some 12 points next time you are there. If the bolts are easily accessible I would recommend pulling five from the intake side and using them on your exhaust side. This obviously is "thinking ahead" and anticipating a blown gasket at some future date.  I don't think 12 point bolts are available new anymore.
2. If you are sceptical about the 12 point bolts (and not so cheap) you can buy new 6 point Torque to Yield bolts.  As of 3-2009 the Ford dealer gets about $28.  The aftermarket bolts are around $40!  The 6 point TTY bolts are a replacement for the 12 point bolts (should you desire to change them).
  The process seems to be torque to 51 foot pounds, re-torque again to 51 foot pounds, then rotate an additional 90 to 100 degrees (about 1/4 turn). I saw information that this gives an equivalent torquing force of about 110 foot pounds.
  Note - you can ONLY use TTY bolts ONCE.  They are said to clamp better because of the "bolt stretch" that occurs. Unfortunately that bolt stretch is what makes them one time only.
  Lastly (if you are really not cheap) you can buy ARP studs. They are about $110.  ARP told me you can reuse them significantly "IF" you don't over tighten them.
Basically it comes down to this: If your car/truck came with TTY bolts you will have to replace them with the same.  If your car came with 12 point bolts you can reuse them, if you choose. But caution should be given to their condition.  I don't think you can purchase 12 point bolts (new) anymore. You can also replace your 12 points with one time use only 6 point TTY's.
  A little personal history: I have 12 point bolts.  I did reuse them because I was cheap, but apprehensively because I thought ALL bolts were TTY.  I recently pulled the same head for compression issues.  It was NOT the bolts or the gasket.  The bolts were tight and the gasket fine.  I had a burnt exhaust valve.
  With anything this is only based on what I found, so apply the information at your own risk. But, frankly there was extreme frustration for me to know what was right.  So, I decided to create this post.
  Hopefully now that you are over the bolt debate you can jump into the 8993 vs 1035 head gasket issues.  Have fun.
Tom
