Date: 01/23/2023 02:22 pm
Date: 11/29/2018 10:26 am
78 hatchback
Date: 03/12/2023 06:50 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 11/05/2016 09:03 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 03/23/2018 09:23 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 06/24/2020 06:12 am
  • Online today: 1,779
  • Guests: 1738
  • Total: 1738
2.3 Head Bolts (need opinions)
Started by Wittsend, March 19, 2009, 09:49:16 PM
Thank you Mike for the link. If they really are $25 from Ford I'll probably risk using their bolts instead of dropping $110+ for ARP studs.
Dick, the bolts (at least in the turbo coupe) are designed for one time only use.  Read the link that Mike posted. Last night I read up on the matter. I can't find the link, but there is a ton of information out there.
  In a nut shell the bolts are designed to stretch to produce their highest clamping force.  However, once stretched they can not be reused. If you do problems include not holding torque and bolts breaking while torquing can occur.
I reused my bolts and have 80 PSI in #2.  It isn't worth saving $25 to purchase another gasket and do it ALL over again.
Tom
Mike Modified
Turbo 2.3 (at least) use torque to yield head bolts that should be replaced each time.
The guys on Turboford.com seem to recommend using the Ford parts for normal turbo use.
A discussion of the price here:
http://www.turboford.net/ubb/ultimatebb.php?ubb=get_topic;f=2;t=050861#000000
Note the website link that has the lowest price.  Good instructions on torquing also.
I've owned 16 Pintos. Raced 4 of them, and rebuilt at least half, and all with the same head bolts used over, some more than one time. So what is your problem?????
I always reuse the bolts. I have never bought new head bolts for any engine. Never had a problem. I know a guy that actually reuses the same head gasket I would not do that.  Fred   :)
Geez..., is it just me or is a real frustration of the 2.3 engine the need (and CO$T) to replace the head bolts - EVERYTIME!!!  >:(
The options appear to be:
1. spend 40.00+ on new bolts (everytime)
2. or $110 on a stud set (hummmm... how many re-torques with a stud set?)
These are prices on Felpro (ES72137) bolts or ARP studs.
Note: I found a place named Headbolts.com that sells a 1067 bolt set for $23.95.  Has anyone used them before?
Does the Ford dealer sell the bolts cheaper?
  What ever happened to the day of reusable head bolts???  This is a steel on steel motor, why the need for such a pricey bolt arrangement?
Input, suggestions, recommendations, are all appreciated.
Thanks, Tom
