Date: 08/20/2017 01:34 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Date: 09/01/2017 07:52 am
Date: 08/22/2017 09:21 pm
Date: 08/30/2018 12:59 am
Date: 09/01/2017 11:58 am
  • Online today: 600
  • Guests: 497
  • Total: 497
Interchageable?
Started by Carolina Boy, March 12, 2009, 04:46:23 PM
Removing the 77/78 bezels isn't all that complicated. There are two bolts on the lower edge where it meets the fenders, these are held together by a small metal plate. Then there are bolts on the four 'corners' of the headlight that need to be removed from inside the fender (IIRC 13mm), then 2 between the turnsignal and grille, and with a little gentle coaxing, it should fall off. :look:
p.s. I have a 'backup plan' too, I have a set of 75 bezels. ;D
Now that is one great backup plan! Thanks for the info! 8)May all your Pinto days be merry!!
billnall
75-78 same fender.
74-78 same hood.
So you can use the 74-76 headlight bezels, turn signal lamps and grille on 77-78.
The headlamp sealed beam, bucket and retainer ring are the same 74-78.
I know what you mean about the 77-78 rubber fender extensions, most of them are are cracked.
I have Bobcat front end parts to put on my 77 wagon.
Ford Parts Man
My 78 headlight bezels (thanks to pintogirl :angel:, I know what they are called) are falling apart. I am hopefully getting s set from pintogirl, if they come off easy. Should that fall thru, will the 76 bezels fit the 78 fenders? I am pretty sure I'd have to use the 76 grille, though.
Also will the hood from the 76 fit the 78? The 78s hood is so rusted, it has pin holes.
I ask this because I want to have a backup plan. :drunk:
