Date: 11/05/2016 09:03 pm
Date: 05/18/2020 10:22 pm
Date: 04/25/2017 12:17 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Pinto drive train
Date: 06/29/2018 08:32 am
Date: 08/26/2018 06:23 pm
Date: 10/02/2017 02:16 pm
  • Online today: 1,293
  • Guests: 1188
  • Total: 1188
Rotisseries
Started by Underdog76, September 21, 2004, 05:40:10 PM
You have got to love the 2x4 propped up on the belly of that MB.
Merc51
Found it !!!!
check out ...
www.kars.com/showcase/mps/
yes London Ontario Canada.
Dennis
Merc51
fyi
I few years ago I read an AD for a device that you would bolt to the wheel lugs on the rear and front of a pinto / mustang. The car could then be rolled (by one hand) over on it's side for easy access to the underneath. It was a steel "cage that was balanced so it would roll with the car on the "inside". the bolting locations were the lugs. Very simple system that worked. They were made by a company in or near London Ontario Canada.
dennis
UltimatePinto
Centering the balance between the four points would definately have to move towards the front if you were to leave the vehicle complete minus the drive train. I would think that the front mounts could take the strain with no problem but the rears by themselves, no way. The doors and then the interior add  an considerable amount of weight
Two pieces of angle iron at least 3/8" thick could be used to connect the two spring mounts on each side, as measured from a common reference ,shims added as neccessary to maintain a fair amount of parallel, (SP?), with the ground. I would guess that the rear is higher than the front. Then the two sides could be connected with a common, centered, load bearing piece that would accept whatever pivitiong device practiceable.
Don't forget that there are holes in the sub frame behind the front spring mounts that may also be used for this potential setup.  I have an early SPEARCO anti axel hop unit that used these holes for a connecting bar. This may mean not using the rear tap's altogether, which would probably be the better choice.
Any way -  Go to   www.accessiblesystems.com  for some ideas. That's the outfit I mentioned before. Often, all you have to do is to study the image and let your imagination and accessibility to materials do the rest.
I've built an acceptable pressure sandblaster doing the same.
In my opinion Detroit stopped making acceptable vehicles in 73/74. As far as acceptable response, (when prepared), and sheer driving FUN ! , the Pinto, (with rack and pinion), was  THE  best of the seventies!
My first Pinto love is with the 71/72's, with the 73's a close second. However I love all of the production line for their mostly ease of interchangeability.
Rock On !
Al
in Ct.
patcosca
I'm worried the bumper mounts wouldn't be strong enough to support the car and it would cause serious damage if it buckled.  I guess it wouldn't take that much more to build a bracket that mounted into all four spring shackles to support the rear.  As long as it was below the pivot point, I think it would still roll over easy.  Another problem I may have is height clearance.  My garage ceiling is about 8 feet high, it should work, but it will be close.
UltimatePinto
I don't think that using the bumper mounts in the rear would be a problem as long as you had the car stripped, inside and out. I can tell you from experience that all you have back there is a box of 14 gauge sheetmetal with a piece if 1/4" angle inside. The rear shackles bolt to it from below and the lower bumper bracket bolts into it from the top. I know this as I just cut mine, (72 Runabout), out and replaced them with a piece of 1/4" wall four inch square tube. See rear impact mod in this listing, General Pinto Talk.
I love the early models also. Unfortunately thats how the 71 and 72 models were made. I have a 71 Sedan that I will be doing the same thing to. I have just finished picking a 74 Sedan apart and noticed the the rear set up was completely different and a lot more beefy. I think that 73 was a transition year as from 74 on the front and rear suspension was changed over.
Al
in Ct.
patcosca
Underdog76, did you end up purchasing the rotisserie?  I am considering one also.  How did/are you going to attach it on the rear?  I'm concerned the bumper mount area may not be strong enough on the early Pinto.
Anybody else have experience with one of these?
UltimatePinto
Yah Buddie ! !
As you indicated, learn by using.
 AH HA.......so you like using the features :D
UltimatePinto
I saw a company that makes them in the front part of the October issue of Hemming's Motor News.
Don't recall who made them. Should be a snap to use on a bare bones Pinto.
Wish I had one for my current project.
Underdog76
I'm probably going to just buy one. There is a company that sells real nice ones on ebay that have jacks on each end so that you can hook them up with the car on the ground and then raise it up. This will be a necessity for me as I plan on building alot of race cars.
Fast as lightning, strong as thunder
Poison Pinto
No, but I seriously have considered building one to work on Poison.
Underdog76
Has anyone ever used a rotisserie while rebuiding/modifing/restoring their pinto?
