77 pinto
Date: 08/22/2017 06:31 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 03/13/2021 12:57 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Rare parts for sale
Date: 09/10/2018 08:38 am
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 09/20/2018 11:01 pm
Date: 04/30/2023 04:31 pm
  • Online today: 1,431
  • Guests: 502
  • Total: 502
2.0, Holley 4bbl ?
Started by 72Wagon, March 01, 2009, 12:01:33 AM
Its a Wieand manifold.  The setup came with a 72 beater I bought last year.  I took it off and replace it with a 2bbl setup before I sold it.
72Wagon
Thanks Tigger, The first thing I noticed is that my carb is on reversed of yours, my throttle is on the left, choke against the cam cover. What intake is that? Mine is a Spearco.
Kevin
1972 Wagon
It is probably not going to be much help to you but it may give you some idea's.  This is what my 4bbl is setup is like.  The return spring is built into the funky linkage converter.  I was impressed with how well this setup worked when I had it in the car.
72Wagon
 I am looking for pics or ideas for a throttle return spring set up for my 2.0 holley 4bbl. setup.  I have tried  a few different setups but they allways seem to interfere with the linkage or just look like crap
I have thought about trying to  run the cable through a compression spring if I can finf one of the right length and tension.
1972 Wagon
