SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 10/28/2018 08:45 am
free transmissions
Date: 11/28/2019 10:21 am
Date: 07/17/2019 05:23 pm
Date: 09/01/2017 07:52 am
Date: 08/03/2017 07:40 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 12/09/2018 11:35 pm
Date: 03/25/2019 09:02 pm
  • Online today: 529
  • Guests: 478
  • Total: 478
Pastic inside panels repair
Started by Carolina Boy, February 28, 2009, 03:59:40 PM
I got two ways to go now. thanks for the help.
I am also a plumbing contractor here around town and you mentioned abs, that is the black drain pipes primarly used in trailers. The white pipe is pvc or pvsc. Two different glues. I will try all the ideas and tell yall which is best.
The panels are actually ABS plastic, which oxidizes over time to a dry, white powder. Go to the website "www.urethanesupply.com" to find a host of products which are used to fix rubber/plastic/vinyl materials of all types. If you write these folks for tips/questions, they are exceedingly helpful.
PVC Cement is what the plumbing pipe glue is, same stuff used on white sprinkler system pipes. You could use that, or you could use the two base mixture epoxy, in the plunger syringe. You could check Home Depot for either of these, or any plumbing store for the PVC cement.
I am replacing the interior panels of my 78 Hatch with the 76s's rear panels. There are holes in each cut for speakers, Since the old panels are trashed,dryrot in the back section, I want to cut out patches to fill the holes in in the new ones. Is there a glue yall would recommend to use? I think I read somewhere that the glue for black plumbing pipes works. Any help?
