  • Online today: 548
  • Guests: 294
  • Total: 294
78 Crusing wagon restore
Started by flash041, February 26, 2009, 04:22:33 PM
Looking good! :surprised:
flash041
today the clear.tomorrow more SANDING and buffing.
Nice handsome '70s colors.  8)
As opposed to all those kitschy '70s colors.....  :P
flash041
Four Pics.Primer,silver,black.Today i hope to shoot the clear.
flash041
Got the black done! ran out of time for the clear.Worked 15 hours straight yesterday.The painting takes only minutes its prep , masking , and taping that takes Hours! Will get back at it this morning , or mabe tomorrow.Ill post Pics as soon as I can.
flash041
Got the base silver on !! now waiting a few hours and will do the black, then clear !
Pintopower
Man I can't wait to see this already!
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
flash041
Barring anything unforseen Ill be painting Friday! By then it will be less humid and in the mid 70's.
flash041
Drip rail done! Now i am ready for paint.Ill do the final light sand with 600 just before I paint it some time next week.
flash041
almost ready! Redoing the LH drip rail.got it primed and  spot puttied today.Its the last area to do.
flash041
Thank you Oh . I am on track to do the base silver , black , clear next week!!Got a different adhisive for the drip edge.I used the same stuff I used for the quarter.My first though was to use that, but I got impatent and tried the other stuff and made a mess. Just goes to show you go with your instinct and take your time!I plan to do the headlight buckets and bumper fillers with the tough up gun mabe tomorrow to have them done.
   I got the tires today .They look good.I like the wider tires.I had 70 series before.
OhSix9
great progress.
the full sized gun makes way less over spray and fog no matter what you are spraying. Noticed the same thing when i was doing the small parts on mine with a touch up gun.  had a massive fog in all 3 bays even with the fans on and the doors open for some airflow.  When we pounded on the rest of the body with the big gun it was far less hazy.
Nice score on the tires too. coopers are great. we used to run em back in our teens. cheap, sharp lookin w nice white letters. cool you found some.
OhSix'
Virgil to Sid
flash041
thank you dave , but the part i made fits perfectly
I have front and rear sheet metal supports for the 77/78 rubber rock guards if you want original Ford parts. They might be spendy to ship though, due to their length.
Good progress, that new chrome strip is going to look great against the new paint! :D
flash041
A better day today! Made a new sheetmetal support piece for the rear bumper rubber filler.The old one was about gone from rust. Also got new insert molding for the bubble windows.
flash041
a set back tonight.I got two part seam sealer for the drivers side drip rail.It came out of the tube really hard, and lumpy.I tried to smooth it out but it would not.So after it dried a bit i started to grind it out, and I got black gooey specks all over the car! I cleaned up the mess  and proceded to chisel it out of the chanel.Re sanded the area , and will try again later this week.On a good note I orderd my new tires! got Cooper Cobra's 205 60 13 .They are discontinued but acan still get them.
Quote from: flash041 on May 16, 2010, 05:03:58 PM
When ever you can make it.
I hope soon, maybe show off the new toy (you'll like it) check my facebook  (not another one :o )
flash041
When ever you can make it.  Got really busy sanding the second layer of filler primer today. After that I spot primer the spot i spot puttyed.The I had a " critical eye" look at it ( my wife) to point out the flaws.Then more spot putty. Looking good! Just about ready for final sanding before paint!
Quote from: flash041 on May 15, 2010, 03:21:00 PM
Whe is your next trip down here ? You are past due!
I know... I know... I need to hang out w/my "loser" friends...
...but "the big move" has me "busy" all the time trying to get organized in the new place. This year I will only be able to "road trip" on the holiday/long weekends and this 1st one it is unlikely I will be able to get away  >:(
I hope soon... just don't hold your breath as it could be awhile  :'(
Use paint to stripe it. Mask each section individually & use the same number of coats for each color to keep the surface level & then clear it. If you do it right you will have a level surface under the clear & once its buffed you will never think of doing it any other way.
Thats a shot of this tecnique used on my '07 Stang
flash041
Whe is your next trip down here ? You are past due! I plan to have the paint on it some time next week or the week after.  l am still undecided on the multicolor stripes , paint or decal. Either way ill have the silver , black , and clear done .
It is simply AMAZING!!!! the progress you have made with this Pinto...
I am really looking forward to seeing it finished!
flash041
Got the side panels on and second coat of primer ! Ill do some more wet sanding this weekend and another coat of primer.
flash041
Worked last night putting up a spray booth at a friend's , who is letting me use the booth.It should be done by next week. My car will be the first car sprayed in it! So I am looking at the end of next week at the earliest,the week after at the latest.
Quote from: flash041 on May 08, 2010, 08:42:43 PM
We will see Mark.Ill need a break after this.Painted the jams , looks really nice and shiney with the clear !
I was goofing around  ;D  We are going to paint the coupe in my drive way with grill (as in BBQ) paint  ;D Say it with Krylon baby  :lol:
Quote from: flash041 on May 08, 2010, 09:52:02 PM
I sprayed the primer and jambs in my garage.I got the supplies at NAPA The product line is ACME Finish 1 . Ive never painted a car with a spray gun before. I just studied it and Ive been in and around the auto repair business for over 30 years.I bought a inexpensive spray gun lit on ebay. $72 for the set of three guns. they seem to work very well, and yes they are all HVLP guns.The etch/sealer primer is the first one to put on. Its a thick primer , i had a couple times where it came out of the gun blotchy, I think because it was a bit cool here this weekend. The filler primer is much thinner . There is very little overspray with the primers.The base /clear is a different story.I used the touch-up gun and thought I would not have much over spray , but after a bit I had quite a cloud !I plan to paint the rest in a spray booth.
If you've never painted before, you'll be amazed at what a difference the spray booth and its down-draft makes.  Good luck!
flash041
Did you spray your primer in the garage? HVLP? What kind of primer?
How did you do your jambs? What kind of paint? With HVLP or spray cans?
Curious since I'll get to this point in a few months myself.
flash041
Guess what he gets to paint next  ;D  Hmm, I have a red/rusty coupe that I want to rat rod and since somebody close to me can paint, well   ;D ;D
GREAT JOB SO FAR!!!  All Ford show is the middle of July so you have a couple of months yet
