Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 12/09/2018 06:59 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Hatch needed
Date: 09/10/2017 09:16 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 02/14/2019 06:27 pm
Date: 09/06/2020 01:57 am
Date: 03/29/2019 07:20 am
  • Online today: 1,086
  • Guests: 1047
  • Total: 1047
T-5 Speedometer gear
Started by Wittsend, February 24, 2009, 09:02:20 PM
Well, I think my hunch was right.  The drive gear on the main shaft was too far back.  If you recall I stated that the tip of the C-4, 18 tooth gear was longer (apparently too long). It is as Doug illustrated with his attachment on post #6.
  My guess is that the cable gear pilot hit the end of the housing (there is no pilot hole at the end).  This bound the cable gear up and the drive gear on the main shaft just followed the locked teeth and pushed itself backwards.
I tried using a screw driver (prying on the teeth to no avail to move it forward).  I removed the shift rod cover thinking I could gain access to the back side of the gear and push it forward. Nope.
Finally I pulled the drive shaft, and found a piece of tubing from and old halogen stand lamp.  The piece was ideal as it fit over the output shaft, but inside the bearing and seal.  I used a screw driver to press down on the retaining clip through the cable input hole and pushed the gear forward.  I now have a speedometer!  Hopefully it will hold. I'm sure glad I didn't have to pull the tailshaft.
Thanks for everyone's help, Tom
Bob, Doug,
  I can definitely feel the internal gear on the output shaft turning. There is no slippage.  And, as I said, the teeth all "feel" there. I've tried to get a look, but between the flashlight, mirror and where I can place my head the view is minimal. It just seems to me that the internal gear isn't getting far enough into the housing to contact the gear on the cable.
My son has a small aerial camera for his R/C plane. Later today I'll try and see if I can get an image into the area.
Thanks for following me through this journey, Tom
turbo74pinto
the worm gear in the t5 is definately nylon and the speedo gear wont always show signs.  same thing happend to me on one of my old pick ups. that worm gear is held in place by a small steel clip between the shaft and the gear.  i have one appart at the shop, ill try to remember to snap pics of it tomorrow so you can see how it looks and is hooked up.  can you see in there with a small mirror?
bob
I wonder if it's possible for the worm to slide down the tail shaft?
What year is your TC? I might see if my manual goes up that new. I have a '70s Ford parts manual for the Pinto and an '80s parts manual for all the Merkur XR4Ti parts transplanted into the Pinto.
OK, upon further review there does seem to be some difference between the T-5 and the C-4 speedometer gears.  Basically everthing is identical except the tip of the gear (round, narrow part where the cable goes) is longer.  I don't know if that means anything. The tip (C-4, 18 tooth) did show very minor mushrooming.
I put my finger in the opening and did feel the internal gear moving. It seemed to have a common cadence so I assume no teeth are stripped.  However, neither the C-4 cable, nor the Turbo Coupe pulse drive indicate any engagement with either the C-4, 18 tooth gear, or the T-5, 17 tooth gear.
Note too (again) there is absolutely NO sign of ANY damage to the cable gear.  You would think if I killed the internal gear "something" would show on the cable gear!
So, I'm really baffled.
Tom
PS: I have a 2.3 with C3 Pinto that's becoming a 2.3 turbo with WC T-5 Pinto. Had 2.79 gears which where wimpy. I am now swapping in 3.25 gears with a LSD. Have a whole set of speedo gears that I bought off eBay to swap around until the speedo reads right, when I get it back together.
According to the Ford manuals, there are a whole lot of speedo gears that look almost alike, but really aren't. The C4 takes a style 3 gear and the T5 takes a style 3a gear. How's that for splitting hairs? The T5 also is listed as having a nylon worm. I'm taking the WAG that the C4 may have its worm machined on the tail shaft.
BTW, you did put the C-clip back on the speedo gear? Just maybe, without it being retained, it might just slip over to where the worm won't turn it.
turbo74pinto
you have it right with the c4 cable to your t5.  the worm gears may be a different design.  it seems that that worm gear will wear before the speedo gear. i dont remember what the c4 worm gear looks like. below is a link to a "t5 guide"  that will tell you how many teeth you have on your worm gear.  at least it will if you still have the tag on your tranny.  that should help with your speedo gear selction.
i put the gear from the turbo coupe onto my pinto speedo cable and its been fine.  maybe that worm gear in your tranny was on its way out from a crappy speed sensor??
bob
http://www.allfordmustangs.com/Detailed/349.shtml
I'm going to look through parts catalogs later if somebody else doesn't have an answer by then, but I believe that Ford automatic gears have a round base and Ford manual gears have a base with six or so lumps around them.
Doug,
  From what I'm seeing on the internet (in numerous places) the C-4 gear and the T-5 speedometer gears are the same.
  Sorry I can't tell you the difference in the speedometer reading as I barely noted it was working, - and then it wasn't.
  For the record the T-5 has a .80 5th gear, I'm using a 3.00 rear end and currently have 225-60-15 tires.  However, I'm likely going to go with something smaller (probably 205-60-15).  Even with the 3.97 first gear it kind of bogs on take off and as close as I can estimate 65 MPH is around 2,000 RPM.
Tom
Did the auto gear chew up the worm gear in the tranny?
BTW, what was your rear ratio and how far off did the speedo read when it was working?
I do know that Ford manuals and automatics take different styles of speedo gears. Get one for a manual.
Hi guys,
  I decided to forgo the Turbo Coupe electronic speedometer and just hook up the factory Pinto speedmeter to my T-5. Basically all I did was reinstall the Pinto C-4 speedometer cable.  For a few miles it worked, then it stopped functioning.  I changed the C-4 18, tooth gear to the Turbo Coupe 17 tooth gear, but it didn't read either.  Note too that neither gear shows any damage and on installation the gear needs to be rotated as though it is engaging.  Also I checked the housing depth and they are bothe equal on the C-4 and the T-5.
  A spin of the cable reads on the speedometer.  I even tried push/pulling the cable thinking it might be an issue (cable popping out at the speedometer), but in all cases the speedometer reads.
  So, I'm baffled.  What would make it read for a mile or so and then just stop?  At this point all I can think of is the drive gear on the tail shaft.  But what would cause that to go out?  Everything "was" spinning freely.
Thanks if you can help, Tom
