1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 05/18/2020 10:22 pm
convert to stick
Date: 05/19/2018 09:26 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Date: 08/22/2018 09:23 am
Date: 02/28/2018 09:37 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Date: 08/05/2018 01:58 pm
  • Online today: 1,779
  • Guests: 1706
  • Total: 1706
driveshaft replacement
Started by volksnut, February 18, 2009, 08:59:51 PM
volksnut
I found it, a 79 mustang was the length I needed, 3 1/2" longer and the same u joints as the Mustang II worked in it
I tried to see on the PCCA map what area you might be in, but you're not on it yet. If you have a Pick Your Parts type junk yard near you or have access to something like it, you may be able to get lucking under a minivan, etc. Other car makes (brand X) can be a good source too. Adaptor U-joints are available that can mix and match almost anything together. Watch for aluminum ones, they're high dollar if you buy a new one but there are a lot of them out there (CHEAP), but look closely, a lot also get damaged when the vehicle is picked up by the wrecking yard fork lift so be selective.
volksnut
Well since you all would be the ones to ask...and to make a long story short, I did a motor swap in the daughters Mustang II, from a v6 to a 2.3. The V6 had a 4 speed (but wouldn't work with the 2.3) and took a shorter driveshaft than the 2.3 and a Pinto 4 spd. trans. I'm looking for a donor for the longer shaft, a wagon possibly? The shaft I have now is 45 1/2" center to center on the u joint. I need a shaft 4" longer at 49 1/2". Any idea's besides building a new unit? thanks
