Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 03/27/2017 10:07 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Date: 02/28/2024 02:07 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Crane Cam
Date: 02/26/2018 07:50 am
  • Online today: 1,459
  • Guests: 122
  • Total: 122
Proper oil pressure?
Started by dave1987, February 10, 2009, 06:52:20 PM
I will keep this in mind Starliner, thank you very much! :)
Starliner
Rule of thumb...
10 psi for every 1000 RPM is excellent
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
That is at it fully warmed up.
The engine was totally rebuilt about 13,000-14,000 miles ago with a Ford kit though.
is that Pressure at Cold temps or warmed up?
Maybe a little low at idle but not bad, assuming it's not a new engine. It only takes about 5psi to turn off an idiot light.
What is the proper oil pressure for a 2.3L motor? Or, what should my oil pressure gauge be reading? at idle it sits at about 10, when revving it I can only get it up to about 43-45. Is this normal?
BTW, I am using a small cheap set of sunpro gauges, but 1/8" copper tubing. All the connections are tight, with no leaks anywhere.
