Date: 05/13/2021 05:33 pm
parts needed
Date: 02/20/2017 07:58 am
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 10/11/2019 11:13 am
Date: 02/25/2017 08:45 pm
Date: 02/16/2019 10:46 am
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 02/04/2018 08:26 am
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
  • Online today: 2,773
  • Guests: 2564
  • Total: 2564
351C IN TO A PINTO NEED INFO
Started by BEDOWERS, February 03, 2009, 08:04:09 PM
NoForKin
also the rad will need to be pushed foward a lot for fan clearance this will entail alot of cutting, also lateral limiters will be needed for the motor or it will twist up like a pretzel
         NoForKin
BEDOWERS
I HAVE A STOCK BOTTOM END WITH HOME GASKET MATCH PORTING JOB VALVE SPRINGS AND ROLLER ROCKERS. CROWER CAM IF I REMEMBER IT IS 563 LIFT.
I HAD THIS MOTOR AND TRANNY IN 68 COUGAR ABOUT 3300 LBS 9 INCH 4.56 28 SPLINE 28.5 TALL SLICKS TOCKER INTAKE 750 HOLLEY.
RAN 11.9 CLASS FASTEST WAS 11.5
JUST A GOOD BACK YARD MOTOR.
HEADMAN MAKES HEADER BUT $700 SANDERSON MAKES SOME SHORTY BUT NOT FOR A PINTO I WILL NEED TO GET MOROT IN THE CAR TO SEE IF THEY WILL CLEAR.
WOULD LIKE TO FIND SOME USED ONES
TRYING TO MAKE ABUGET BUILD
THANK YOU FOR THE HELP
BILLY
turbo74pinto
id think the 8 inch would be fine.  joe morgan went 10.75 with a detroit and stock axles.  9 inch spools can be machined down for use in an 8 inch housing.  if you go that route, you can go 31 or better spline with an aftermarket axle.  like noforkins implied, those cleveland based blocks are WIDE.   that may be a concern for the headers, and the whole front end for that matter.  comp engineering hase 8pt cages for 189.  price may have changed from the last i looked.  slicks....biggest you can fit.  26-10.5-15 fit with some massaging.  although, keep in mind, drag radials have recently hit high 6s in the quarter.
bob
NoForKin
what are the specs  on the 351 if its potant you will need a 9in rear.  headers will need to be coustom built unless you front half you car. my pinto runs in the low, mid 10,s
           NoForKin
BEDOWERS
 HI
I AM GOING TO TRY TO BOILD A CAR FOR PINKS ALL OUT IN INDY.
THIS IS WHAT I HAVE AND WHAT I NEED ALL HELP IS NEED.
I HAVE
80 PINTO
ENGINE PLATE
351C
C6
8 INCH
STALL CONVEROR
NEED
HEADERS
BELTS
CAGE
SLICKS
LINE LOCK
SHIFT RACING
IF ANY LEADS OR WHAT I NEED TO DO PLEASE LET ME KNOW
BILLY
