72 Pinto parts
Date: 12/04/2018 09:56 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 11/11/2019 03:38 pm
Date: 04/24/2018 11:45 am
Date: 08/30/2021 03:20 pm
Date: 02/05/2020 11:06 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
  • Online today: 2,773
  • Guests: 2610
  • Total: 2610
deck heigth...
Started by kemerick, September 14, 2004, 07:17:30 PM
pintojoe
Esslinger racing catalog has a measurement for the head:
Measure from where your rocker cover sits on the head to the block mating surface.     2.0 stock length = 3.728
                2.3 stock length = 3.800
The block measurement would be how far the piston sticks above the block surface into the headgasket(remember to use a compressed gasket)
The head planing gains compression and reduces piston to valve clearance, spark plug to piston clearance.
Plan your cuts.
Pintojoe
1973 Pinto runabout, 2000cc,4spd.
Deck height is measured from the crank centerline to the head mating surface. My trusty Haynes manual doesn't list this measurement though
 Good question. I know there is a distance on the head, from the deck to the valve cover mating surface that will indicate how much has been removed off the head. I need to look in my files for that measurement. As far as the block go's ????? dont know.
kemerick
How can I tell if the head has been decked too many times?
How can I tell if the block has been decked too many times?
