Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 10/31/2018 12:04 pm
Date: 06/22/2017 07:19 am
Date: 05/24/2020 08:19 am
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
pinto for sale
Date: 09/11/2016 09:47 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
78 hatchback
Date: 03/12/2023 06:50 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
  • Online today: 2,440
  • Guests: 2257
  • Total: 2257
Fuel tank vent valve
Started by dave1987, January 24, 2009, 11:18:38 PM
I dropped the tank and replaced the valve and grommet. Posted pictures of the process in my project log. Thanks everyone!
Starliner
Yes, there is a 90 degree plastic elbow with a grommet at the top of the tank.
As posted above, you can get these from SSCEnterprises - www.sscenterprises.net
You need to pull the tank to get to this.
As a temporary fix, drill a super small hole in the plastic valve on the inside of the gas cap.
That will vent the tank to prevent a pressure build up.
You can check if you did it right by blowing & sucking on the cap.
If you can get air in both directions.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
SSCEnterprises - www.sscenterprises.net carries these. I just got a new one for my tank.
I replaced my filler neck grommet last summer, I'm not to worried about that seal. It's the vent valve grommet I'm trying to find.
Someone here just replaced their valve and grommet, but i can't find the thread.
Gregg
i bought the filler neck groumet from ford dealer for $13.00 . the tank is not to hard to get out .
Is it located on top of the tank? I noticed that the last time I gassed up, I smelled some fuel fumes in the car until the fuel got down to a little over 3/4 full.
How hard is it to drop the tank and replace that valve and grommet? Also, where can I get a new grommet? I have a valve off a 77 bobcat tank that should work.
